This engine has been standing on it's belly since I bought it. I mounted it last weekend on a mock-up firewall on a stand to be able to start sorting out manifolds etc. With it off the workbench I could see underneath it and discovered that the push rod tubes on one side has all been dented inwards in a straight line. The engine seems to have been dropped at the one side on an edge of some sort.
Volkspares sell these at R85-00 but I need to buy a complete gasket set to get the seals for the tubes and the paper cylinder gaskets.
Is there any place where I can source these without having to buy a complete gasket set?
VW Type 1 Engine push rod tubes and gaskets
Rhino? Fck the Rhino, save the White Ou.
(met permissie van Gyronaught)
Re: VW Type 1 Engine push rod tubes and gaskets
Thanks to some e-mailed advice I got the tubes fixed.
Dankie!
Dankie!
Glad to hear you came right
Jean.
Jean.
And tube seal also sorted
Glad for you Eddie
Jean.
Jean.
Thank you Jean
Users browsing this forum: No registered users and 100 guests
