sport copter rotorblades
has anyone any experience with sportcopter rotorblades in South Africa
Re: sport copter rotorblades
How can I help???
That is my R/Blade set up I will be re fitting to the Xenon Im rebuilding, Im no expert nor AP (cant lower my workmanship to AP level
What do you need
I will be re doing this entire set up in a few days and have been doing my homework
What do you need
PPL (A)
PPL (H)
CFI Gyro & Test Pilot
PPL (H)
Thanks for the reply Greg. I have ordered the conversion for RAF rotorblades and hubbar from sportcopter. Have done a lot of research with USA users and got very posetive response. Mine should be here towards month end. Will keep in contact
That is very interesting? If I may ask why?
I had the opportunity to help to assemble a RAF some years back, what is the motivation to change? I found the quality of the locally supplied RAF kit to be exceptionally well manufactured.
Will the blades come pre assembled on the hub bar? (could be a bit large) if not you will need to hang and string the set up as far as Im aware?
Would be very interested to get feedback from you on this project, Please keep us in formed and if possible pictures from when you remove them from the crate.
Just remember the teeter bolt assembly must be hand tight in that the bolt must be able to rotate by hand even with the blades hanging on the teeter bushes, its important to shim it like that and then the safty pin must just butt up against the retaining bolt.
PPL (A)
PPL (H)
PPL (H)
Greg send me your contact number.
Peter
Peter
Kolibri,
This is not the rotarycraft forum, and we really don't need too much of what goes on there regurgitated here ad nauseum.
You've posted barely a handful of (mainly duplicated) posts on this board and I honestly can't decide whether you're here to discuss in a constructive manner or simply looking for a new platform upon which to engage in a carryover of your apparent RAF-bashing agenda?
You'll notice that this forum (and dare I say this gyro community as a whole) is a lot more polite and less devisive than its Rotarycraft forum counterpart. We'd like to keep it that way please.
Dave Lehr
Magni Gyro M22 ZU-EPZ
NO Please it sounds like Avcom
PR
PR
First RAF in South Africa to fly with Sportcopter rotors. Now no more worries of bolt failure on hubbar.
Mooi Im glad to see your trip to CT a few weeks ago let our workmanship skill rub off on you.....spinkaan wrote:First RAF in South Africa to fly with Sportcopter rotors. Now no more worries of bolt failure on hubbar.
It looks fantastic!!! how does it feel...oh dont bother I will feel it myself and comment
PPL (A)
PPL (H)
PPL (H)
So looking at this from an engineering angle? this set up must make tracking adjustments a breeze???
Peter is it a single bearing Head??? using a 3206 /5206?
PPL (A)
PPL (H)
PPL (H)
Hi Greg, this is a standard RAF gimblehead with a double row angular contact ball bearing 3206. The tracking is a piece of cake and the blades are abselutely balanced. This is a real quality product.
Eben, what does your reply
mean?
What are you "shocked" about?
Kolibri
Kolibri
RAF2000, with Boyer H-stab and Sport Copter upgrade (mast plates, rotorhead, hub bar, rotors, 4-way air-trim).
Am also a fixed-wing pilot and owner. I fly 200+ hours/year, mostly VFR x-country.
