B- Box gearbox for sale
dirkvlog
Slow starter
Postby dirkvlog » Fri Apr 22, 2016 10:17 am
I had to replace the gearbox because we are going to aero tow hang gliders with the trike and I need a hollow shaft gearbox (C or E) for the tow line attachment.
Gearbox: It is a B Box with a 2,58 gear ratio. Only 38 hours on it. The gearbox is in a very good condition and oiled up on the inside. There is some corrosion on the outside part that connect to the prop, but it is very light surface corrosion only, I put oil on it to not get worse. (Please see attached photo's) Due to this I have dropped the price to R2000
Both these items are just taking up space in my garage and I know I will never use it.
I am based in PE
Dirk van Loggerenberg
You can contact or wattsapp me on 084 440 2974
B Box 3.jpg (45.28 KiB) Viewed 719 times
B Box.jpg (54.06 KiB) Viewed 719 times
Prop 3.jpg (85.82 KiB) Viewed 719 times
