582 Blue Top/ 582 Silver Top.
Postby Blue Max » Sun Apr 10, 2016 1:39 pm
Sorry for my ignorance. :mrgreen:
Can anybody briefly explain to me what difference will there be in a Rotex 582 Blue Top with 480 HRS on the machine in comparison with a Sliver top, 582 with the same HRS.
Thanks very much.
Re: 582 Blue Top/ 582 Silver Top.
Postby Air Hog » Mon Apr 11, 2016 8:06 am
Postby Duck Rogers » Tue Apr 19, 2016 10:33 pm
Blue Max wrote:Sorry for my ignorance. :mrgreen:
Thanks very much.
Paul...
Grey crankshaft = 17mm thick conrods and 24mm crankpin
Blue crankshaft = 18mm thick conrods and 26mm crankpin
by the way...Grey or Blue cranks makes no bloody difference. I see an equal number of crank failures.
Cooling system modified on the Bluetop to prevent cold seizures. Fly the Greytop right and you wont have a cold seizure either
Rubber seal on Greytop waterpump shaft changed to a Ceramic seal on the Bluetop. A definite improvement
That's only the changes between the two. I presume that's what you meant with your question otherwise its impossible to tell the difference because its 2 different motors flown differently in different conditions for 480 hrs. You will have to open them both up inspect and measure everything ( I don't think that's what you meant but that's what you asked vhpy )
Postby Madman » Wed Apr 20, 2016 9:04 am
Howdy puff
Flying my trike which is a Silver Top and having flown Oom Polla's Raptor over the Easter weekend which has a Blue Top...the only big difference I noticed is that when you put the silver top in a dive, it drops the water temp very quickly, so you have to keep her at an idle to maintain water temp...with the blue top, you do not see a drastic water temp change when thrown into a dive ##
Also with the warming up in the mornings, the Silver top does take a little longer, but nothing to write home about ^
On the performance side, I did not feel a difference in power -xX
So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker :mrgreen:
s023
coline
Postby coline » Wed Apr 20, 2016 10:28 am
" So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker :mrgreen "
In a spiral dive you should watch the ground, not the water temp. :)
Postby Duck Rogers » Wed Apr 20, 2016 10:34 am
Madman wrote:...the only big difference I noticed is that when you put the silver top in a dive, it drops the water temp very quickly, so you have to keep her at an idle to maintain water temp...with the blue top, you do not see a drastic water temp change when thrown into a dive ##
s023
And that's exactly why they changed the cooling system on the Bluetop.
Performance wise there is no difference. Its the same specs on both
Postby Madman » Thu Apr 21, 2016 9:44 am
coline wrote:" So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker :mrgreen "
Yeah :lol: ##
