I have installed 2 led lights on my wings to use for landing and taxiing. they
have a lot of noise interferance on the radio. is there a remedy for it?
LED interferance
LED interferance
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Re: LED interferance
I was told it results from lights not properly shielded and that it can be overcome by installing a ferrite coil as close as possible to the light.
The coil gets installed "in-line" or you get a snap-on coil going over the power cable.
I am sure you will get them at Communica.
Roel Jansen
ZU-IAR powered by BMW 1200
Thanx Bru, i did`nt think of the ferrites. will try some...
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Had the same problem after fitting LED strobes to my gyro several years ago. Tried ferrites without success - replacing the wiring to the strobes with thicker gauge wiring did the trick.
Dave Lehr
Magni Gyro M22 ZU-EPZ
The ferrites did`nt work. will try thicker wiring...Thanx Learjet..
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
