Agents for Garmin GPS's & Easy Cockpit Software
Eagle
Postby Eagle » Mon Aug 14, 2006 9:17 pm
Get the very best in Navigation & Flight Planning ! We do a absolute winning combination between a Garmin M4 GPS (Pocket PC) and the Easy Cockpit Software. We also assist with the initial setup of the GPS (Pocket PC) as well as the installation of the Easy Cockpit Software to the Garmin M4. Also Included is the SA Roadmap V4. So you can use it in the Air as well as on the Road and at a fraction of the cost of conventional GPS's with a Jeppesen Database !
Give us a Call if you need more Info.
Package Includes:
iQue® M4 Pocket PC
Garmap South Africa Streetmaps
USB charge and synchronization cable
AC wall charger
Auto cradle
Owner’s manual
Quick-reference guide
Easy Cockpit & Easy Plan Software
Nic Prinsloo
Managing Member
Eagle Aviation
Where Flying is a Passion......
Branch Contact Info:
Mobile: 076 970 2758
Skype: nicprinsloo
Email: Eagle@connect.co.za
African Grey
Postby African Grey » Sat Aug 26, 2006 6:32 pm
As per the spec...what sort of cost is involved for the Road and Jepperson/Flying version?
Eagle
Postby Eagle » Tue Sep 26, 2006 4:02 pm
Herewith some answers on all your questions:
1) The price on the Garmin M4 PDA/GPS: R6900-00 incl vat.
More Info on http://www.garmin.co.za/prod_detail.php ... egoryid=13
Package Includes:
iQue® M4 Pocket PC
AC wall charger
Owner’s manual
2) If you need a Cradle for it extra to mount it and to give battery power, it is R 450-00 incl extra.
3) Easy Plan Flight Planning + Easy Cockpit Moving Map software for Pocket PC, incl. Easy Plan,Easy Wheather and Electr. Logbook:R2699-00 incl
4) I will do the initial setup & installation of the programs for you absolutely free !
Nic Prinsloo
Managing Member
Eagle Aviation
Skype: nicprinsloo
Nick
Postby Nick » Sat May 12, 2007 10:56 am
GPSs are way over priced in SA. I'm not sure where in the 'food chain' the clearly excessive mark-up is slapped on.
No matter; fortunately there is a way of by-passing the local supply chain. Garmin GPSs can be sourced much cheaper than in SA - like almost half price - by ordering off the web from GPS City. No duty is payable on GPSs; you only have to pay 14% VAT on the converted US$ value on landing. Typical order to arrival time is 5-10 days.
I know plenty of folks who have done this without any problems in the 4x4 arena. Some multiple times.
I've heard of local suppliers citing warrantee issues and mapping issues as an argument against sourcing overseas, I find those arguments thin at best, since whatever the default maps on the unit, you will be loading local mapping data, the units are very reliable (I know of only one that had to be returned to Garmin) and if they do go wrong, ship them out to be fixed/ replaced - simple. The only other real argument for sourcing locally, is to support local suppliers. I'm happy to do that, but not if I'm being ripped-off - all too common with manufactured goods in SA.
Just be careful that you know the spec of the machine you buy.
Quentin Ferreira
GPS
Postby Quentin Ferreira » Mon Jun 25, 2007 10:49 am
Do you only have does gps's in stock or a dif moddel??
Quentin Ferreira
ZU-ATP
Newcastle
Eagle
Postby Eagle » Mon Jun 25, 2007 2:47 pm
Hi Quentin,
I have the whole range of Garmin GPS's available - Just let me know which one you want and i will get it for you.
Nic Prinsloo
Managing Member
Eagle Aviation
Skype: nicprinsloo
Quentin Ferreira
GPS
Postby Quentin Ferreira » Tue Jun 26, 2007 8:54 am
Nic are you going to be at Virginia air show???
Would like to see how they work as a sample???
Quentin Ferreira
ZU-ATP
Newcastle
Eagle
Postby Eagle » Tue Jun 26, 2007 12:46 pm
Hi Quentin,
There is a possibility - I will let you know.
Nic Prinsloo
Managing Member
Eagle Aviation
Skype: nicprinsloo
