Breakfast at Boris Benic's - 16 December 2015
mulderpm
Postby mulderpm » Fri Nov 13, 2015 10:55 am
Boris is hosting his well known breakfast once again . Breakfast , coffee/ tea with rusks at Benic's airfield on Wednesday 16 December 2013, starting from 6am. All welcome.
Benic's co- ords, S 25.80380 E 29.21386, alt 5100 ft
Benic's TRC - 124.8
Witbank - 123.5
Runway 09/27 690m x 5m
Join overhead right hand downwind for 27 or left hand downwind for 09 (uphill)
Stay clear of house on N side and of chicken farm,
Hazard, power line on approach to 27 east side
Be aware of nearby FAWI active traffic (123.5)
Fuel by arrangement
You can call Boris on 082 338 3054 or 013 -6973941
See you there. (^^)
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
RV12
Re: Breakfast at Boris Benic's - 16 December 2015
Postby RV12 » Sat Nov 14, 2015 10:12 am
From what time Paul ?
mulderpm
Postby mulderpm » Sat Nov 14, 2015 1:01 pm
Edited original post.
Paul Mulder
ZU-DBC Aquilla
Pretoria
RV12
Postby RV12 » Sun Nov 15, 2015 6:33 am
witwillem
Postby witwillem » Sun Nov 15, 2015 7:45 pm
Sal dit probeer maakwilgraag die plek sien sien net footoos by die rhino se manne (^^) w itwillem
witwillem
Postby witwillem » Sun Nov 15, 2015 7:46 pm
Postby Bundy » Tue Nov 17, 2015 6:42 am
Will join the Tailwinds gaggle if I'm not working.... (^^)
Postby Madman » Thu Nov 19, 2015 7:21 am
Sounds good ##
The Chain Gang will try and make it this time...last time there was a CB in the way, then diverted to Aeroden for coffee and from there routed to Potch to check the gliders, but found nothing as they all went to Welkom for a comp ##
ME 109
Postby ME 109 » Thu Nov 19, 2015 4:10 pm
I will join from Secunda. Hope to meet the tailwinds gaggle there (^^)
Andries Kruger
Jetman
Postby Jetman » Thu Nov 19, 2015 4:49 pm
Will see you guys there.
ZU-FDE Apollo Delta Jet
ZU-IHK Sling
ONE LIFE....LIVE IT
Christo-FCN
Postby Christo-FCN » Mon Nov 23, 2015 12:55 pm
Christo van Rooyen
0795645668
0825136820
Postby Blue Max » Thu Dec 03, 2015 6:31 am
vhpy
Sit my naam ook op asb,
Postby Blue Max » Thu Dec 03, 2015 6:33 am
Mooi Chris, jou foto vertel alles in n oogwink.!
mulderpm
Postby mulderpm » Thu Dec 03, 2015 8:05 am
Thanks Christo. Landing on 09, if possible, is recommended, as in the picture. 09 is slightly uphill and you stop at Mr Benic's facilities. But if you are use to Microland, with its power lines on 03 & 09, then 27 at Benic's should be no problem.
Paul Mulder
ZU-DBC Aquilla
Pretoria
MILO
Postby MILO » Tue Dec 15, 2015 6:59 pm
27 not cool. You will reach the threshold at around 6m agl, have to deal with rotors from the north westerly over the hangars and blue gums and probably reach touchdown halfway down the runway.
At this time of year the threshold of 09 can be a bit muddy so you will backtrack through it.
Also 27 will put you in conflict with traffic joining on finals 09.
We can chat tomorrow.
