Quicksilver MXII
Staggerwing
Found a flight school
Quicksilver MXII
Postby Staggerwing » Thu Oct 15, 2015 11:16 am
R20,000 onco.
Western Cape
Cell. 082 seven seven zero 57 six 9
2013 043.JPG (70.01 KiB) Viewed 4314 times
2013 044.JPG (81.19 KiB) Viewed 4314 times
2013 045.JPG (94.96 KiB) Viewed 4314 times
2013 046.JPG (79.79 KiB) Viewed 4314 times
Re: Quicksilver MXII
Postby Air Hog » Thu Oct 15, 2015 1:59 pm
More info will be required
Engine Type?
Hours?
Wing material condition?
Current ATF?
Logbooks?
Slabfish
Postby Slabfish » Thu Oct 15, 2015 9:12 pm
Yes ,all the above and belt type on drive ?
Clem Slabbert from FAPX
ZS WPF Mizer-Sold
ZU EKP Jora-Sold
ZU CWE Jora-Sold
ZU IAC New Jora
Postby nicow » Fri Oct 16, 2015 7:48 am
This is a nice toy to have...
Suesing
Postby Suesing » Fri Oct 16, 2015 10:50 am
Good fun
Jabiru Instructor ( Grade B)
Staggerwing
Postby Staggerwing » Fri Oct 16, 2015 2:15 pm
Engine hours or airframe hours not sure there is a log book.It has a vive belt maxidrive with +- 60 inch prop.The motor is single ignition 503.Think last atf was 2007,have not tested the fabric since then,could still be fine.Motor starts easy and pulls well
Staggerwing
Postby Staggerwing » Fri Oct 16, 2015 2:31 pm
According to log book hours is +-365.,not sure how accurate this is.Back in the days this type of flying was hardly regulated.
buxter
Postby buxter » Fri Oct 16, 2015 10:53 pm
I am interested in this aircraft. Can anyone on this forum give me more info on these light aircraft.
Will you get airborne at 4000ft (FAVY), two up at 100kilo's each.
If so, what climb rate can one expect?
hummer
Postby hummer » Sat Oct 24, 2015 9:23 am
Hi is this a quicksilver or a Basic 4000
Where is it based
Are the photos recent
Staggerwing
Postby Staggerwing » Sat Oct 24, 2015 8:31 pm
Read post
silverwings
Postby silverwings » Sun Nov 01, 2015 9:44 pm
Hi Staggerwing
Where in the Cape are you. I'm urgently on the look out for a Quicksilver, I had a basic 4000 but unfortunately lost it in an accident due to a broken tail. There is no better LSA than this.
Staggerwing
Postby Staggerwing » Thu Dec 17, 2015 10:04 pm
Hi Silverwings
You can call me
Staggerwing
Postby Staggerwing » Thu Mar 24, 2016 5:20 am
Aircraft is still available
