With the latest shocking news of the terror incidents in the UK, this must place pressure on the requirements for transponders.
eish ZULU1
Transponder issue may just now become law ?
- ZULU1
- John Young
- The Boss
Re: Transponder issue may just now become law ?
Eish ZULU1 – 8 to 10 planes targeted – plans to cause unimaginable damage and consequent loss of human life, but –ZULU1 wrote:With the latest shocking news of the terror incidents in the UK, this must place pressure on the requirements for transponders.
ZULU1, where is the connection to transponders? On Microlights? Am I missing something here?
- John Young
- The Boss
- ZULU1
Security issues relating to transponders
John; a few years ago the UK almost banned microlights and so on because of foot and mouth, you could only take off and land at the same point, the UK CAA is very strict... After 911 they discussed at length regarding fitment of transponders so they could see where people are with respect to safety and security both on and above the ground. Corridors everywhere.
This disgusting latest incident may just tip the balance and with it a worldwide consequence. Thank God they were caught..someone in the British Police needs a Knighthood.
As regards a transponder I had one on CEW a few years ago, it worked wonderfully and was a pleasure to use.
A Filser now is about ZAR15k from Composite Technologies that is Mode A, C and S with altitude encoder and all the other good things.
eish Zulu1
eish Zulu1
- ZULU1
Transponder
The biggest problem is the ZAR 15k !! but I spent a few hours fitting mine as I made it "quick removable" and laser cut the brackets and so on. The antenna ground plane was under the back seat (an Aquilla), I cut up an ally curry pan, the type sold in Chakas kraal with dimples and all. The deep section was cut away to create two legs, the pot being about 200mm in diameter. The little stub antenna screwed in neatly. I fitted the transponder just below the front seat and it hung down, the enclosure came from Electro Mechanica. It was larger than the newer Filser as it had a alti encoder in it. The Filser should be easier to fit, it replaces the Altimeter. Enough interested parties I could make up a fitting kit for them. Will dig up the pics and post them. Its use was wonderful, called Deben approach, and squawked, down the beach front Sunday morning with a height and a vector, a real pleasure, even big iron could see you and was also pleasant. Some chaps at the club toyed with the idea of sharing one, which is a good idea as its quick fit is convenient, saves sand ingress on the beach when not needed. But for us at Ballito/La Mercy to travel to the South Coast it saves the flight around Alveston tower to the South Coast. ATC Deben gave me a letter allowing three trikes on 1 transponder...and stated - behave yourself !!
I even flew into Virginia with it, used to fly- taxi to the end to dodge the landing fees bike...he still caught me though. With the ZAR 15k would definitely buy another one and would really enjoy it.
eish ZULU1
eish ZULU1
- Biggles
Zulu1
Being a techie maybe you could explain what makes a transponder so expensive? I thought that all it was was a tranmitter squacking a code on radar frequency?
And will the proposed legislation insist on altitude encoding?
Could the cost come down if it becomes a worldwide necessity?
And I still don't see the piont... it can be turned off if you are doing something you shouldn't be doing... adn then your invisible aslong as they don't have tracking radar(think its called tracking radar). Which apparently most civil airports don't have anyway...
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
- Leprachaun
Hey Zulu1 , its all good an well , but ze PRICE - its a great idea to fit it , but >>>>>
What about our own hitech Gurus , Rainier and Philipe - come on guys local is lekker , most trike fly skydat and some will soon have the Enigma , so wheres
the check your mate ?????
- Biggles
Morph why not fit one of those sirens the stuka dive bombers use
That would definitelyy get the people off the beach!!!
On a more serious note, whenever the transponder issue comes up there is usally a enigmatic reference to alternative technology... is that a stall tactic or are there cheaper alternative out there?
- StukaAttack6.gif (87.49 KiB) Viewed 1566 times
- dive bomber
- derek-siren.jpg (10.61 KiB) Viewed 1565 times
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
