Hi guys
I need some advice on the following:
Windlass trike with 503 UL DCDI, B type gearbox and Aquilla wing. The prop is an old Geo Kelly 63-32 wooden prop that was serviced last year by Peter de Necker and has barely worked since. Prop looks great. Now the problem is I have a MGL Avionics Smart Single EMS 503 that shows me 7000rpm during take-off. I downloaded the the Rotax manuals from the internet and they show peak performance of 37kW at around 6500rpm and give a max allowable rpm of 6800. My questions are:
1. Am I doing damage to the engine at 7000rpm for a few seconds during take-off? I don't want to cause long term problems.
2. Can it be that the EMS Rev counter can be so far out?
I spoke to Peter de Necker and he was concerned about the high revs and recommended to stay below 6700rpm. He also said he doesn't want to sound like a salesman, but he would recommend a prop with a higher pitch. He says a 63-35 will do better and provide a higher cruise speed with the faster Aquilla wing. Makes sense to me! Any thoughts will be appreciated.
Props and RPM
Props and RPM
ZU-ARS
Re: Props and RPM
In any case it is better to have a resettable step to fully utilize the power of the engine.
Sabre 1600 mm 63 "will be just right.
It will be quieter, softer rod will be greater.
7000 - this is not normal, often can not be used.
It is necessary to set the fin so that the earth was 6300-6500.
Not more.
Not more.
Re: Props and RPM
Don't do it.Am I doing damage to the engine at 7000rpm for a few seconds during take-off?
Roel Jansen
ZU-IAR powered by BMW 1200
