2009 BANTAM B22J NEGOTIABLE DONE AND DUSTED THANKS GUYS
877hrs MANUAL LIFTER, 80 HP JABIRU ENGINE
ANALOGUE ASI , VSI, ALT, SLIP INDICATOR, OIL PRESS, OIL TEMP, CYL HEAD TEMP, COMPASS,STROBE LIGHT.
BRAND NEW FLIGHTLINE 760 VHF RADIO ,CERTIFIED INSTALLATION ,R18 000 (MARCH)
CERTIFIED INSTALLATION OF AERIAL ,INTERCOM AND TWO HEADSETS ,SERVICED (MARCH)
BRAND NEW PROPELLOR DESIGNED BY MICROAVIATION -MADE BY PIET DE NECKER ,R9 000.00 2900 RPM (FEBRUARY)
NEW TYRES ALL AROUND WITH ANTI PUNCTURE MOOTY ( 6 PLY ) (TWO SPARES IN REASONABLE NICK)
NO.1 NO.4 NO.5 DOWN TUBES REPLACED RECENTLY (ROUTINE MAINTENANCE)
RECONDITIONED BRAKE HANDLE, BRAKE PADS
FIBREGLASS POD REMOVED , RE FIBREGLASSED ON INSIDE / REPAINTED (RECENTLY)
INSTRUMENT PANEL REMOVED , RE WIRED BY CERTFIED TECHNICIAN, PANEL REPAIRED (RECENTLY)
LEADING EDGE, FLAPERONS, ELEVATOR TREATED EVERY 3 MONTHS WITH SILICONE/ NIKKIWAX (SKINS GOOD CONDITION )
NUMBER 4 CYLINDER OVERHAULED DUE TO "LAZY RINGS" (FEBRUARY) ALL 4 BLOW BYES STRONG @ 850 HRS
AIRCRAFT RUN ON AVGAS RUNS AT A GENUINE 12 LITRES/HR
25 HOUR MAINTENANCE HISTORY WITH APPROVED CAA MANUAL (PART 61)
BATTERY REPLACED EVERY WINTER
MAINTAINED BY REPUTABLE AMO AT FAKR (PART 61)
REASON FOR SALE - HAVE ORDERED A BATHAWK
NO ACCIDENT HISTORY
AIRCRAFT COVERS,FAKS AND STRIPS,FIRST AID KIT.
POINTS TO PONDER
THE AIRCRAFT WILL NEED A TOP OVERHAUL AT 1000HRS (INCLUDING LABOUR , LESS ONE CYLINDER HAVING BEEN DONE RECENTLY,TODAYS QUOTE FOR OVERHAUL- R19000.00) THE AIRCRAFT IS GOOD AFTER THAT FOR ANOTHER 1000 HOURS - THEN TOTAL ENGINE OVERHAUL.
IT HAS RECENTLY BEEN ESTABLISHED IN AUSTRALIA, THAT THE 80HP MANUAL LIFTER ENGINE DOES NOT SUFFER FROM OIL COOLING PROBLEMS SO MUCH SO, THAT THE NEW GENERATION ENGINES (CAMIT) ONLY COME OUT WITH MANUAL LIFTERS, PROOVING THE RELIABILITY OF THIS ENGINE.
BANTAMS ARE CERTIFIED IN NEW ZEALAND,THEREFORE THE WORKMANSHIP AND MATERIALS ARE OF A HIGH STANDARD. I HAVE TRIED TO KEEP MY BANTAM AS ORIGINAL AS POSSIBLE.
THIS BANTAM FLIES STRAIT AND LEVEL HANDS OFF (AVERAGE GPS SPEED OVER 4YRS 54KTS) NO SNAGS , GET IN AND GO ANYWHERE RIGHT NOW.
I AM WILLING TO ACCEPT A REASONABLE DEPOSIT , AND RE-PAYMENT TERMS OF THE BALANCE THEREAFTER. R145000 NOT NEGOTIABLE. R140 000.00 CASH BUYER NEG 0825677489 valleyflights@hotmail.com
- prop1.jpg (35.41 KiB) Viewed 2901 times
- cockpit.jpg (27.45 KiB) Viewed 2901 times
- seats.jpg (26.8 KiB) Viewed 2901 times
- wing.jpg (22.5 KiB) Viewed 2901 times
- engine.jpg (32.2 KiB) Viewed 2901 times
- wiring engine.jpg (26.85 KiB) Viewed 2901 times
- front view.jpg (24.19 KiB) Viewed 2901 times
- tail.jpg (20.22 KiB) Viewed 2901 times
Jabiru Instructor ( Grade B)
Re: 2009 BANTAM B22J NEGOTIABLE
Cash buyer : R140 000
- Going for flight test
- Air Hog
- The Boss
Re: 2009 BANTAM B22J NEGOTIABLE DONE AND DUSTED THANKS GUYS
Question: Why bump a post of a plane that was sold in April?Tortoise man wrote:bumb
you ask me ,well it is purely out of stupidity I did not see it was sold.
AS THE OLD SAYING GO, NO GOOD DEED WILL GO BUY UNPUNISHED.
