912 Bing Carb Q
Nacho
912 Bing Carb Q
Postby Nacho » Fri Apr 03, 2015 9:52 pm
I have a 912 80HP machine. The one carb keeps overflowing and pushes petrol out of the overflow pipe.
I decided to buy 2 x new carb kits, new floats, new float brackets, new diaphragm etc etc etc. After removing the carbs, cleaning it properly, installing the new carb kits, the same carb is still overflowing. Why is this happening? Any ideas? ##
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
justin.schoeman
Re: 912 Bing Carb Q
Postby justin.schoeman » Fri Apr 03, 2015 10:41 pm
The usual suspect is the float needle and seat. If those were replaced too, then need to look elsewhere.
Saw an interesting one the other day, where the engine mount rubber were shot. The vibration prevented the needle from seating, and it flooded.
Nacho
Re: 912 Bing Carb Q
Postby Nacho » Sat Apr 04, 2015 6:41 am
Yes new needle and seat as well, complete carb overall kit. The engine mounting is a very interesting one... I will check it out. It is only the one carb that does this.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
Nacho
Re: 912 Bing Carb Q
Postby Nacho » Sat Apr 04, 2015 2:56 pm
Checked all engine mounts. No issues there.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
pit bull
Location: Rwanda- Work, Grassland sports facility home base
Re: 912 Bing Carb Q
Postby pit bull » Sat Apr 04, 2015 8:42 pm
Nacho wrote:I have a 912 80HP machine. The one carb keeps overflowing and pushes petrol out of the overflow pipe.
Hi nacho,
try and phone flo members, I am sure he can help.
His number: 082 666 2000
Hope you get sorted, and please tell- what you found.
Veilig vlieg
pit bull.
Blessed By THE BEST.
Nacho
Re: 912 Bing Carb Q
Postby Nacho » Sun Apr 05, 2015 12:35 pm
Ja, sal met Flo gesels, as daar iemand is wat sal weet is dit hy.
Wonder of die compensation tube tussen die 2 carbs die probleem kan wees. Die een wat op was is deur geskaaf, en vir toets doeleindes het ek sommer n gewone rubber pyp hier ingesit.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
