Rotax 582 Problem
salem
Rotax 582 Problem
Postby salem » Sun Mar 08, 2015 6:26 pm
After I switch off the ignition switch, both magneto switches and the electric fuel pump switch, the prop keeps turning very slowly for about 10-15 seconds. Any ideas what the problem could be? How do I solve it? I'd really appreciate some help!
ZS-VFZ
Nacho
Re: Rotax 582 Problem
Postby Nacho » Mon Mar 09, 2015 4:29 pm
Your starter properly earthed? Battery all good? Test it, new batteries comes with a 3 month warrentee for a reason.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
Leprachaun
Postby Leprachaun » Mon Mar 09, 2015 8:38 pm
Sounds like an earth/ electrical problem to me .
I suggest you check all wires and connecters , Alex
justin.schoeman
Postby justin.schoeman » Mon Mar 09, 2015 8:43 pm
Not sure about 2 strokes. In a 4 stroke, I would suspect excess carbon/lead deposits in the combustion chamber, and/or incorrect spark plug. Either of these will cause serious damage to the engine if not attended to.
Postby Bundy » Tue Mar 10, 2015 5:05 am
salem wrote:After I switch off the ignition switch, both magneto switches and the electric fuel pump switch, the prop keeps turning very slowly for about 10-15 seconds. Any ideas what the problem could be? How do I solve it? I'd really appreciate some help!
Salem...is the engine still firing after you kill the spark? You should be able to hear it if this is the case?....Then I tend to agree with Alex...could be a bad earth on one or both magnetos.
If not, then what does the compression feel like when you turn the prop? If your compression is very low then the prop will take much longer to stop dead.
Ours takes 2-3 seconds from switches off to dead stop.
