Gyro project - Advice needed
mynard
Slow starter
Postby mynard » Sun Dec 28, 2014 1:59 pm
Hello aviators..
I'm currently looking at acquiring a partly built Sycamore Mk1 Gyroplane, as a project to complete myself.
I have walked the terribly restrictive road with the CAA on a previous occasion w.r.t a type certified aircraft and ended up loosing huge financially because of my own haste in making a purchase.
Learning from this I need to ask the wise, experienced and educated individuals of this forum for some advise, before sticking my head into another possible hornets nest.
What should I look out for when looking at a project like this. This being a ZU type experimental aircraft that has been half build bar the motor and a few odds and ends.
Do I need a build number from the CAA?
What paperwork should I get with the aircraft in order to continue the build?
What sort of extra costs can I expect for things like air worthiness and test flights etc?
And any other info you might deem necessary would be greatly appreciated.
The aircraft has apparently been registered before as ZU-JSB, not sure why it's no longer registered.
Kind regards,
Mynard..
Steve_SP
Re: Gyro project - Advice needed
Postby Steve_SP » Tue Dec 30, 2014 7:00 pm
Hi Mynard,
Can you confirm your Sycamore is serial number SYCA0025 ?
If so first registered in July 2001 - Avdex suggests it is still registered.
"ZU-JSB" was previously earmarked for SYCA 0011 - this became ZU-VIV but was damaged beyond repair in a rollover in 2000 - hopefully you've not got this machine ?
Steve
