Magni M16 Gyroplane for sale
Postby Gyronaut » Wed Dec 17, 2014 9:13 am
Falkor, the legendary flying cotton-candy luck dragon of Never Ending Story is for sale!
The machine can be viewed at Morningstar Airfield in Cape Town and is available immediately.
HOURS:
Engine: 451.7 - full service history
Airframe: Rebuilt/Major overhaul - 2013 by J Froneman, AP#33
All spares supplied by B Brown of Magni, AP#149
PRICE
R460k
TECHNICAL SPECIFICATIONS:
WEIGHT
Empty weight 290 Kg
Maximum take-off gross wt - 550 Kg
Useful Load - 260 Kg
PERFORMANCE
VNE 115 mph
Cruising speed 90 mph
Absolute ceiling 13,000 ft
Service ceiling 11,400 ft
Take-off roll zero wind 230 ft
Landing roll from 0 to 100 ft
Rate of climb 950 ft/min
Fuel tank capacity 72 ltr
Endurance 3.4 h
Range (no reserve) 300 miles
DIMENSIONS
Rotor diameter 28 ft
Propeller diameter 67 inch
Overall width 1800 mm (71 inch)
Overall lenght 4655 mm (184 inch)
Overall height 2600 mm (103 inch)
DESCRIPTION
Airframe: Chrome-alloy aeronautical 4130 steel, tig welded. Fibreglass fuselage canopy. Fibreglass wheel pants. Fibreglass instrument panel.
Seat: With integral fuel-tank manufactured in epoxy resin reinforced with fibreglass.
Instruments: Mode C Transponder, Radio, Rotor Tach, Altimeter, Airspeed Indicator, Flydat or EIS engine monitor
Engine: 914 Rotax Turbo, 4 cylinders, 4-stroke, water-cooled, 115 hp with electric starter and mechanical prerotator.
Propeller: Arplast 67 inch three-blade carbon fibre with ground adjustable pitch.
Rotor: two-blade, composite materials.
Controls: Dual.
Trim Electric
EXTRAS
* Mode C Transponder
* 8w Panel Mount Radio.
* Vertical Speed Indicator
* Compass
* AirSpeed Indicator
* Altimeter
* Rotax Flydat Engine Management System & Rotortac to Monitor Rotor RPM’s
* 2 x Headsets and Intercom System
* Upholstered Soft Seat Covers
Contact owner, Jonathan Basckin - 083 461 7796 or Len Klopper - 082 450 6072 to view.
