Hello All
I have a Garmin 195 GPS.
Does any body have the PC/computer interface cables that I can purchase?
Cigarette lighter charger would also be handy to have.
Garmin 195 GPS
Re: Garmin 195 GPS
Hey Guys
I know this is a scarce item. Have tried all sorts of sources but no luck.
I have killed for less
Re: Garmin 195 GPS
Try cape avionics!It's in your valley.Regards Johan.
Re: Garmin 195 GPS
Thanks Johan. Tried them but did not have in stock.
Found other items that I needed though.
Re: Garmin 195 GPS
http://www.shopwiki.com/l/garmin-pc-int ... gpsmap-195
http://www.skygeek.com/garmin195-access.html
Have you tried google? I found the link above - do not have the time to search it - am sure you can check if they have something that will work.
To fly is Heavenly but to Hover is Divine!
Re: Garmin 195 GPS
Ek soek ook een vir die 195 ,ek het n paar interface kabels maar weet nie hoe die een moet lyk nie ,kan jy my jou no sms na 083-675-3377.Miskien kan ons iets uitwerk ,
Groete ,
Francois
Groete ,
Francois
Re: Garmin 195 GPS
Is the 195 cable the same as for the 196 ? Is this the cable ?Bayliner wrote:Hello All
viewtopic.php?f=13&t=23090
Re: Garmin 195 GPS
Hallo RV
Not the same cable.
Not the same cable.
