(SOLD ) For Sale - Star Streak shadow with Jabiru Engine ZU - CJR ---R97 000 ----(SOLD)
Engine - Jabiru 80hp - 376 hrs
Airframe - 376 hrs
Authority to fly valid to -12th March 2015
Registration - ZU CJR
Mass and balance valid to -13th march 2019
All Papers up to date
Icom A3E Radio
Flight com intercom
Flight com head set x 1
Duel control
Electric trim
Vertical speed indicator
Altimeter
Air speed indicator
Side slip indicator
Rpm Gauge
Oil pressure Gauge
Temperature Gauge
CHT Gauge
Fuel gauge
Volt meter
Hour meter
Carb heat
Compass
12 volt power point x 3
Fire Extinguisher - new
Battery new
Fuel 95 Unleaded (Mogas ) or Aviation fuel or mixed
Back up electrical fuel pump
Fuel tank 45 litre capacity
Endurance Solo +-4 Hrs and endurance with a passenger +-3.5Hrs
Best fuel consumption which i achieved is : 7.5 Litres P/H at 60MPH (50% power)- Solo
VNE - 140 Mph
Cruise - 85Mph to 95 Mph
Full power - 120 Mph
Climb - +- 800 Fpm at 2000 feet Agl Solo
3 Blade warp drive propeller
Microlight flies very well
Always Hangered
Cross wind capability -20 Knot cross wind at 90 degrees
Glide ratio - +- 18 : 1 Solo
Microlight based in Manzini Swaziland
Price - R97 000
Reason for sale - With tough laws regarding the opening of the new International Airport in Swaziland i can no longer get permission to fly this South African registered Microlight in Swaziland as i am a permanent resident
Can deliver it by trailer(but trailer not included as i need it ) to almost anywhere in SA then rig it up and test fly it , however would prefer an interested person to come to Swaziland to have a look at it first
Contact : Dion +268 76085066 Cell or diondun@yahoo.com
Star Streak Shadow with Jabiru Engine for sale 376Hrs(SOLD)
- Star Streak Shadow jabiru engine -.jpg (32.66 KiB) Viewed 6523 times
- Star Streak Shadow Jabiru Engine.jpg (33.68 KiB) Viewed 6523 times
- Star Streak Cockpit.jpg (37.77 KiB) Viewed 6523 times
Re: Star Streak Shadow with Jabiru Engine for sale- 376 Hrs
What a Bargain!!
Aquilla II ZU-DJS
Wingfield - 124.8
Wingfield - 124.8
very nice
Jabiru Instructor ( Grade B)
What is the maximum weight in the pilot seat
- Blue Max
Wat se nonsens is dit???Micronuts wrote:Reason for sale - With tough laws regarding the opening of the new International Airport in Swaziland i can no longer get permission to fly this South African registered Microlight in Swaziland as i am a permanent resident
What is the length of the wing from tip to tip.? Want to know if it will fit into my hanger.
Maximum weight of pilot? also want to know if I need to loose weight.?
I am serious! ( although I just had a brandy)
- Ready for the first flight
Weight and height of the pilot please! Does a tall person fit in that little space
i weigh 82 kg and am 165cm . The cockpit can take a much taller person as i have to use 2 x pillows behind me to touch the rudder pedals .i cant say exactly how tall as its not specified in the manual . In this microlight the pilot does not sit upright but lays back in a very comfortable position with very good visibility .I have taken a very tall passenger for a flip with no issues . Being obese sideways could be a challenging issue as the width of the cockpit and passenger area is more suited for a normal built person . According to the manual the maximum pilot weight is 86Kg , however the cockpit can take a maximum weight of 97.5Kg(Means heavier Pilot needs to take less aboard the cockpit ) and a minimum of 55kg .The passenger section can take maximum 91kg and minimum 0kg . The wing span is 8.5 Metres and height to top of rear fins is 1.75 meters
The height is not a problem but front seat weight is a problem for me. Otherwise great plane
According to the manual the recommended Pilot weight is 86Kg , however the cockpit can take a maximum weight of 97.5Kg and a minimum of 55Kg. This means a heavier pilot needs to reduce the weight of what he carries aboard into the Cockpit . The passenger section can take a maximum of 91Kg and a minimum of 0 Kg
Hi Who built the plane and any damage history
Does the rear seat take a taller person than the normal shadow and does it have the stronger landing gear
Adrian. Look at this informative website:hummer wrote:Hi Who built the plane and any damage history
http://freespace.virgin.net/shadow.owners/index.htm
The following from the web but with the 582:
Streak Shadow Sales Specification
The CFM
Streak Shadow
The Streak Shadow has been developed from the award winning series produced Shadow Microlight. Categorised as a homebuilt amateur produced aircraft it is designated as a 'Ultralight' in Europe and 'Experimental' in the U.S. The new design of wing coupled with light airframe weight and the powerful engine gives this aircraft OUTSTANDING performance. Staggering acceleration and exhilarating sustained climb rates are combined with 100 mph hands off cruise. CFM's new wing retains the inherant saftey with its aerodynamics of no 'defined' stall and is very spin resistant. With a total fuel capacity of 12 imperial gallons (14.4 U.S. Galls) and endurance of approximately five and a half hours at economic cruise a range of about 400 statute miles is normal.
If a trailer is used for transport the Streak can be readied for flight in less than 10 minutes. Take off and landings can be accomplished from runways, sports grounds and meadows. Fun combined with safety are the key factors when flying a Streak Shadow. .
AFTER ALL, SEEING IS BELIEVING.
STREAK SHADOW SPECIFICATION
PERFORMANCE:
Never Exceed Speed vne .................. 140 mph.....225 kph
Maximum Level Speed...................... 121 mph...... 195 kph
Cruise - Economic 50%...................'.....75 mph......121 kph
Max Continuous 80% ......... 100 mph...... 161 kph
Minimum Speed MTOW .......................31 mph.......50 kph
Climb Rate - Solo .......1600-1800 ft/min.....488-549 m/min
- Dual........ 1100-1300 ft/min.....335-396 m/min
Ceiling ...............................................29,000 ft.......8839 m
Fuel Consumption :
Economic Cruise 50% ....................2.1 gall/hr.......9.5 Itr/hr
Max Continuous Cruise 80%...........3.3 gall/hr....... 15 Itr/hr
Crosswind Capability ................................25 knots at 90°
DIMENSIONS:
Wing Span .............................................28 ft..........8.53 m
Area ................................................ 140sq ft.........13 sq m
Length....................................................2V..............6A m
Height.....................................................5'9".. ........1.75m
Empty Weight.....................................388 Ib .......... 176 kg
Max. Take Off Weight .........................900 lb...........408 kg
Engine .....................................................Rotax 532 64HP
...............................................Twin Cylinder Liquid Cooled
Propeller.....................................52"x55"3-Bladed Wood
Fuel Capacity ...................................12 Imp gall........54 Itr
Controls .............................................................Dual Stick
........................................................................Dual Rudder
.......................................................................Dual Throttle
...................................................................................Flaps
.................................................................................Brakes
Rigging .....................................................Separate Wings
..................................................Removeable Tail Surfaces
......................................................... 10 minutes Rig/De-rig
Options ...........................................................Electric Trim
................................................................Additional 9.5 gall
The Microlight Manufacture / Builder is Low JA and it is one one the later models build with the strong under carriage . I have taken tall passengers with no problem as it has a foot well in the passenger compartment which lowers the seat . I can't compare to the other Shadows as i am not familiar with them . I am not aware of any damage history as i bought it as a flying machine and have had no incidents while in my hands . I have just really enjoyed flying it as it very agile and handles turbulence like it does not exist .
Users browsing this forum: No registered users and 36 guests
