Just wondering if anyone has or seen some type of fuel flow meter installed on an aircraft, iether instantanious (l/h),cumulative (total L) or average l/h. Maybe someone in the automotive industry knows of products that could be used on a trike.
I think it would be quite useful for monitoring feul on long cross-countries.
Anyone know the cost and implications of installing something like that?
Fuel management
- Biggles
Fuel management
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
I have a fuel flow system installed in my plane. It's made locally in South Africa by MGL Avionics. It's brilliant. You can use it with or without a fuel level sensor. I have both the fuel level sensor and the fuel flow meter installed so it gives me
Total fuel available
current fuel flow
range in hours of remaining fuel.
Range in distance
If you don't have a fuel level sensor then you need to tell it how much fuel you have everytime you put fuel in. Works quite well this way. It then calculates remaining fuel based on usage.
It's the right square gauge. The left one the the 503 engine management gauge, with Dual EGT, Dual CHT, RPM and Hobbs meter
Visit their site at http://www.mglavionics.co.za/
The products fall under the Smart Singles and is the FF-1
current fuel flow
Range in distance
There are couple available. Standard in most of the bigger bliks. The certified versions are very expensive. Nirren may also have...
I have MGL Ultra which has built in fuel flow in KRII and it works well. Ranier at MGL also most helpfull...
