In-line OIL filter - service interval
mulderpm
Postby mulderpm » Fri Jun 13, 2014 12:18 pm
Does anyone know at what intervals the two stroke oil filter, located between the oil bottle and the pump, needs to be replaced?
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
Turbo
Re: In-line OIL filter - service interval
Postby Turbo » Thu Jun 19, 2014 7:40 pm
i would change that every 50hours -- not sure what the book says though.
mulderpm
Postby mulderpm » Fri Jun 20, 2014 3:36 pm
Thanks Turbo. There is nothing about this in any book from Rotax nor in their maintenance schedule....that is why I am asking. Fuel filter is inspect 50hrs and replace 100hrs.....2 stroke oil filter???????
Paul Mulder
ZU-DBC Aquilla
Pretoria
witwillem
Postby witwillem » Sun Aug 03, 2014 6:31 pm
Ekke sou senie langer as100 ure , wat kos n nuwe pomp of erger nog n nuwe engine , my se buurman kannie verstaan hoekom sy trkkers nie hou nie filters te duur , hy steek gate innie airfilter met spukers ???
Postby Boet » Wed Aug 06, 2014 1:24 pm
Dis n baie fyn siffie. Haal uit en was skoon met petrol. Sit terug. No problemo. ( Witwilmpie, jy gee sulke oulike raad. Hou van die spykers ene....... :lol: :lol: :lol: )
Frank Smallwood
Postby Frank Smallwood » Mon Aug 18, 2014 6:39 am
To add a question to this thread. Where can I get the filter for the autolube oil? I am in the process of changing the fuel and oil pipes and want to change the autolube oil filter as well.
Cheers Frank
RV12
Postby RV12 » Thu Sep 18, 2014 9:09 am
Boet wrote:Dis n baie fyn siffie. Haal uit en was skoon met petrol. Sit terug. No problemo. ( Witwilmpie, jy gee sulke oulike raad. Hou van die spykers ene....... :lol: :lol: :lol: )
Boet, my 582's oil filter looks like a closed unit ? If so, where do I get a new unit ? Probably from the ROTAX agents.
RV12
Postby RV12 » Thu May 21, 2015 1:42 pm
Frank Smallwood wrote:To add a question to this thread. Where can I get the filter for the autolube oil? I am in the process of changing the fuel and oil pipes and want to change the autolube oil filter as well.
Cheers Frank
Should we buy this oil filter from the Rotax agents ? It actually looks like a fuel filter....
Nacho
Postby Nacho » Fri May 22, 2015 10:17 am
Let me open a can of worms... ##
Pre-Mix...
* Less weight, because you remove the pump, bottle and the 2L oil you carry with.
* Less that can go wrong, pump fails, the filter in mention clogs up, oil pipe starts leaking.
* Because you premix you know there is definitely sufficient lubrication.
* You have one less thing to worry about.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
RV12
Postby RV12 » Thu Apr 07, 2016 11:24 am
Cheers Frank
http://cometaviationsupplies.co.za/inde ... oil+filter
John.com
Postby John.com » Thu Apr 07, 2016 6:37 pm
Rotax Oil Filter - Inline.jpg (5.86 KiB) Viewed 3202 times
Price: R404.53 ## ## ## ##
I would support changing at 100 hours. The 2-stroke oil comes in sealed containers and therefore the chance of any contamination is extremely low.
John Comley
Magaliesberg, South Africa
John.com
Postby John.com » Thu Apr 07, 2016 6:44 pm
mulderpm wrote:Thanks Turbo. There is nothing about this in any book from Rotax nor in their maintenance schedule....that is why I am asking. Fuel filter is inspect 50hrs and replace 100hrs.....2 stroke oil filter???????
On the fuel filter I inspect at the 25 hour service and change if needed, but change every 50 hours.
IMPORTANT NOTE: Use Rotax recommended fuel filters. A friend of mine had an engine out the other day after using a pleated-paper filter, which gummed up with the pre-mixed fuel.
Also, when ordering be sure to stipulate straight or 90 degree bend.
Rotax - Fuel filter 90 deg-228x228.jpg (5.1 KiB) Viewed 3202 times
Rotax In line fuel filter-228x228.jpg (7.89 KiB) Viewed 3202 times
John Comley
