503 vs 582 vs 9xx
Johannvs
503 vs 582 vs 9xx
Postby Johannvs » Mon Jul 17, 2006 1:46 pm
Hi, can you guys tell me what is the better engine to have, I know about speed, weight etc, but from an operation and reliability side.
503, 582, 9xx
Then maybe something about TBO etc…
Johann
RudiGreyling
Postby RudiGreyling » Mon Jul 17, 2006 2:13 pm
Hi Johann,
that is a 'loaded' question for a first post...do a search on this website, a lot has been discussed already, if still unclear then ask again..
http://www.RudiGreyling.com
Postby Morph » Mon Jul 17, 2006 5:11 pm
Without a doubt 4 stroke are more reliable and have a much longer TBO. But they are also much more expensive. It's horses for courses.
I believe in two stroke motors but if money was not an issue then I would immediately go the 4-stroke route.
You are still prone to the biggest single cause of engine outs and that is fuel mismanagement. Dirty filters, bad fuel, crack in fuel lines etc can and do happen to both.
Johannvs
503 vs 582 vs 9xx
Postby Johannvs » Mon Jul 17, 2006 5:53 pm
Thank you so far for the guys that replied, I am getting some info in. :D
Johann
Postby Morph » Tue Jul 18, 2006 9:06 am
Here is a comparison of cost of ownership taking services etc into consideration. It shows that the 503 and 582 are cheaper to own and run until around 1200 hours. So if you are going to keep your plane longer than 1200 hours then the 4-stroke becomes the more cost effective solution.
http://www.gregperkins.co.za/flying/ima ... arison.xls
Johannvs
Postby Johannvs » Tue Jul 18, 2006 10:07 am
This is cool, thank you
Cloud Warrior
Postby Cloud Warrior » Tue Jul 18, 2006 10:17 am
Except 1 Canadian $ = R 6.35 nowadays!
Postby Morph » Tue Jul 18, 2006 10:34 am
updated thanks
