How do you physically move your Light AC
Keep them level
Postby Keep them level » Fri May 09, 2014 7:49 am
Hi All Aviators
Is moving an AC by grabbing the prop be detrimental to same and cause the "degree" settlings to change, in time?
I have a Ground Adjusted Three Blade Prop.
When physically moving the AC, one would only grab two of the three blades. In time could this cause problems?
Raven
ZU-FBL
Dish
Re: How do you physically move your Light AC
Postby Dish » Fri May 09, 2014 8:00 am
I wouldn't grab any of the blades. Take hold of the hub of the prop or as close to as possible if you have a spinner. Also just thinking out aloud but your hand shouldn't move the blades if you move the plane.. I fear if that's possible theres a bigger problem looming.. -
RV9
DISH
