AVIATICA 890 SINGLE SEATER ( baby mic )
ernstvander
Postby ernstvander » Mon May 05, 2014 6:44 am
EK HET N AVIATICA 890 MET 243 URE. FOR R55 000
FRESH ATF EXP MARCH 2015
NOU NET GEDIENS.
ICOM RADIO MET BUZZCOM INTERCOM.
3 BLADE CARBON FIBRE PROP.
LONG DISTANCE TANK ( 70 LIT )
2 X WING TANKS 25 LIT
PLANE IS IN VERY GOOD CONDITION
GOT DOORS ( CAN BE REMOVED )
BURNS ABOUT 16 LIT P/H
CRUISE 110 KPH
EXALENT PLANE CAN BE USED FOR CROP SPRAYING TO.
IF SOME ONE CAN HELP ME I CAN POST SOME PICTURES.
ernstvander@gmail.com
0722466609
GideonBeukes
Re: AVIATICA 890 SINGLE SEATER ( baby mic )
Postby GideonBeukes » Mon May 05, 2014 11:21 am
Engine? En ure op engine?
ernstvander
Postby ernstvander » Mon May 05, 2014 11:42 am
Engin is n 618 met 3 blade warp drive prop en het 241 ure.
Bullseye
Postby Bullseye » Mon May 05, 2014 2:38 pm
pm sent
The Sky is not my limit, it is my playground!!!
Bushbabie
Postby Bushbabie » Mon May 05, 2014 3:09 pm
GideonBeukes
Postby GideonBeukes » Mon May 05, 2014 7:18 pm
Where does it live?
ernstvander
Postby ernstvander » Tue May 06, 2014 6:36 am
In Ellisras
ernstvander
Postby ernstvander » Tue May 13, 2014 6:44 am
bump
ernstvander
Postby ernstvander » Thu May 22, 2014 10:26 am
AVIATICA NOW R50,000,,,,DIE 3 BLADE WAT DAAROP WAS IS GESTEEL MET MY TOYOTA BAKKIE,HET NOU N 2 BLADE OP GESIT.
AS IEMAND IEWERS N 3 BLADE WORP DRIVE KRY VIR N BARGAIN SAL DIT MOONTLIK MYNE WEES.ASOOK N 64 2 BLADE.
Postby Blue Max » Thu May 22, 2014 5:40 pm
:shock:
Wie in Ellisras wil nou n prop van n aerie afsteel.?
Aan wie gaan hy dit verkoop.? :?
Sorry vergeet om te se dit is n mooi aerie.
Wonder of daar nog is.?
avgas
Postby avgas » Thu May 22, 2014 7:38 pm
Oom Giep se ou airy :wink:
ek het hom al gevlieg. very lekker (^^)
Balls to the wall
ernstvander
Postby ernstvander » Fri May 23, 2014 6:32 am
Jy sal verbaas wees wat hier alles aan die gang is.Ek het die prop laas saterdag afgehaal om te kyk of hy sou pas op my Genesis( sy 2 blade het ek ook afgehaal) dit op my bakkie (toyota 4x4) gesit en sondag oggend steel die @#%$%^ my bakkie met die 2 propellers op.NUWE SA!!!
ernstvander
Postby ernstvander » Thu May 29, 2014 6:49 am
NIEMAND WAT BELANG STEL IN MY BABY VIR R49500 NIE ??
ernstvander
Postby ernstvander » Mon Jun 02, 2014 6:21 am
GENTS HIER IS N NUWE DEAL,GEE MY R30K KONTANT EN EN IETS WAT R20K WERD IS...MAAK MY N DEAL
ernstvander
Postby ernstvander » Wed Jun 11, 2014 7:06 am
Gents die radio van die vliegtuig is uit gehaal en vervang met hand radio,die 3 blade is mos gesteel soos in vorige mail,het nou sy oorspronklike 2 blade terug gesit.
Vlieg amper elke dag nog met hom,
Is nou in die mark vir R45.000 en nie onderhandelbaar nie.
Ernst
