I am curious about the frequency of prop strikes from gravel, etc on bush strips comparing tractor v pusher props, and particularly vs the props situated high off the ground - as in the Bat Hawk and Bantam.
Has anyone seen a study? Anyone operating from a bush strip with both types of planes have observations?
I think the high mounted tractor props must reduce the strikes - but is it a big difference?
Cheers,
Scott
Prop strikes from runway debris; tractor v pusher
- Looking at the sky
- Rudix
- The Boss
Re: Prop strikes from runway debris; tractor v pusher
Hi Scott,fosterkane wrote:Hi,
Cheers,
Scott
I have owned and flow pushers and tractors and a tractor will always have less damage from strikes, if the engine is mounted high like the Bantam it is even better.
The problem with a pusher is that at exactly the time when you are going fastest and kicking up the most debris you rotate and then the prop gets even closer to the ground. Also with the prop behind the wheels you get more stuff in the prop.
Agree.
It seems as if it's not the main wheels that throw up most of the stuff, but rather the nose wheel.
A guard/cover on just the nose-wheel , made a huge difference.
interesting comment Baitbird, now I wonder if there are any stats on taildragger pushers v tricycle.......
Users browsing this forum: No registered users and 82 guests
