It seems that the VW just isn't going to work with the HDS wing. I am switching to a Jabiru 3300, and would like to sell the AeroVee.
The complete build thread so far is here:
viewtopic.php?f=23&t=10232&start=555
Here is a video of take-off and climb performance:
http://www.youtube.com/watch?feature=pl ... WHYHNyskvE
All the details are on the build thread, but here is a brief run-down.
AeroVee 2.0
90 hours before I purchased it, and did a complete rebuild
10 hours since rebuild
New parts:
Engine case
Both heads
2 cylinders and pistons
Bearings, rings, gaskets, etc.
Everything else has been magnafluxed and measured
All ADs and SBs complete
Due to a slightly under size crank nose, I have replaced the press fit hub with a Revmaster style taper hub.
Known problems:
Oil leak on front main seal
Oil leak on flywheel seal
(Neither leak is significant. Total oil use in first 10 hours < 300ml.)
Large mixture variation with fuel level (pressure regulator and electric pump included but not fitted).
Aerodynamic climb/dive tests indicate approx 77hp engine output (normalised to sea level).
Available to view (running) at Rhino Park for the next week, or two - until I start stripping to fit the Jab.
Can sell engine only, or complete Raven FWF.
R45,000 (neg) for complete FWF.
Thanks,
Justin
AeroVee 2.0 plus Raven/Zodiac FWF for sale
Re: AeroVee 2.0 plus Raven/Zodiac FWF for sale
BUMP...
Price highly negotiable.
Pickling it this weekend, so last chance to see it run.
Aerovee now has a Turbo upgrade kit for current 2.1L motors @ R43k, don't know if it will work on this 2.0L and maybe it's a bit much but still cheaper to buy this motor and the upgrade kit than to buy a new motor.
http://www.aeroconversions.com
AeroVee Turbo Specifications:
Horsepower: 100 hp @3400 RPM
Max. Cont. RPM (Below 5000' MSL): 3200 RPM
Max. Cont. MAP: 40 in HG
Bore: 92 mm
Stroke: 82 mm
Displacement: 2180 cc
Compression Ratio: 8.0:1 for AvGas 7.0:1 for Auto Fuel
Oil Capacity: 3 US Quarts
Oil Type: SAE Multigrade 20/50 (see Approved Oil Specifications)
Firing Order: 1-4-3-2
Spark Plugs: Autolite MP4163 or equivalent
Carburetor: AeroInjector ACV-C07S
Starter: SkyTec Geared Starter
Alternator Output: 20 Amp
Weight: 185 lbs less oil 152 lbs (Equipped with Nikasil Cylinders)
Propeller Drive: 1:1
Prop Bolt Pattern: Qty 6, 5/16" diameter @ 4" Center
Prop Drive Bushings: 9/16" diameter x 7/16" long
Battery Required: 12v @ 20 Amp
Bore: 92 mm
Stroke: 82 mm
Flying feeds the soul!
Thanks for the bump Jaco. Even though this may put a damper on the sale, I would personally not consider turbo-charging the type-1 VW (turbo-normalising - like Revmaster does - would be OK though). The bottom end is rock solid, and will handle this fine. But I don't see how you can keep the heads cool at those power levels.
But if someone does want to go that way, the turbo kit would fit on this engine without much trouble.
Pleasure Justin, if I had the money I will go this route but with the nikasil cylinders, think it would be perfect for the Turbulent.
Sonex must have found a way to keep the heads cool as they sell it now as one off their engine options. Maybe leave it for a year or so to see what happens with it in the Sonex.
If one looks at Aero-Vee cyl-heads, and you have a Revmaster cyl-head next to it , you can clearly see all the major differences. The Revmaster head has MUCH more cooling openings than the Aero-Vee, the casting is also of a better and thicker quality.justin.schoeman wrote:Thanks for the bump Jaco. Even though this may put a damper on the sale, I would personally not consider turbo-charging the type-1 VW (turbo-normalising - like Revmaster does - would be OK though). The bottom end is rock solid, and will handle this fine. But I don't see how you can keep the heads cool at those power levels.
J
Yes - and even then, Joe only rates his turbo version at 85hp...JeanTree wrote:If one looks at Aero-Vee cyl-heads, and you have a Revmaster cyl-head next to it , you can clearly see all the major differences. The Revmaster head has MUCH more cooling openings than the Aero-Vee, the casting is also of a better and thicker quality.justin.schoeman wrote:Thanks for the bump Jaco. Even though this may put a damper on the sale, I would personally not consider turbo-charging the type-1 VW (turbo-normalising - like Revmaster does - would be OK though). The bottom end is rock solid, and will handle this fine. But I don't see how you can keep the heads cool at those power levels.
J
Justin yes that was the R2100 rated @85 hp. The R2300 will be substantially more. They are busy with that project
J
J
OK - this is something new then. When I phoned Joe (admittedly a few years ago) he said that he would turbo normalise it, maybe with a mild boost. But he did say that he was not going to increase the rated maximum continuous power.JeanTree wrote: Justin yes that was the R2100 rated @85 hp. The R2300 will be substantially more. They are busy with that project
J
Users browsing this forum: No registered users and 31 guests
