Hi Guys.
At the beginning of next month I need to fly my trike from Melorani wildlife preserve in the Northwest to Kroon airfield, to have the annual inspection done. I fly an Aquilla 582. I put the route into vfr planner as a straight line and it seems to be pretty simple, not changing radio frequency much (the only change being Aeroden/Aviators paradise, unless I skirt it). Can you guys please have a look and see if there is anything to be on the look out for and any tips or advice?
Thanks very much.
Brad
Flight from dirt strip in the Northwest to Kroon
- Looking at the sky
- John.com
Re: Flight from dirt strip in the Northwest to Kroon
Hi Brad,SAwonderer wrote:Hi Guys.
Thanks very much.
Brad
Sure, please provide a link to your plan.
Cheers,
John
John Comley
Magaliesberg, South Africa
Thanks John.
First time I have used VFR planner so I hope you will be able access the link
http://www.vfrplanner.org/app/nav/vfrpl ... 6467793341
- Dish
There shouldn't be any change for either of those and nor for kroon. Theyre all on 124.8 ?/
RV9
DISH
DISH
- John.com
Yes, perfect! Your flight plan looks fine. 124.800 all the way!SAwonderer wrote:Thanks John.
Remember, Kroon circuits are both AWAY from the mountain!
For your interest, I am including some reporting points and ADs in the area (kmz files for Google Earth) which you can report your position from once in the area, remembering that this area north of the Magaliesberg mountains is fairly active insofar as training goes!
Safe flying, John
- Aeroden.kmz
- (493 Bytes) Downloaded 1592 times
- FAAP - Aviators Paradise.kmz
- (505 Bytes) Downloaded 296 times
- FABS - Brits.kmz
- (495 Bytes) Downloaded 369 times
- HBV VOR.kmz
- (771 Bytes) Downloaded 315 times
- ODI.kmz
- (727 Bytes) Downloaded 296 times
- Red & White Radio Mast.kmz
- (729 Bytes) Downloaded 438 times
- Rustenburg AD.kmz
- (1.09 KiB) Downloaded 539 times
John Comley
Thanks for all the help guys. Thanks Dish for the tip, wasn't sure if they had local frequencies. 124.8 all the way
Thanks John, I appreciate the Points of interest.
Bye for now
Bye for now
- John.com
My pleasure, glad to be of help!SAwonderer wrote:Thanks for all the help guys. Thanks Dish for the tip, wasn't sure if they had local frequencies. 124.8 all the way![]()
Bye for now
One final note, the last few miles (about 5-6 miles, looking at your routing) flying into Kroon are in Johannesburg Special Rules WEST, so frequency 125.800. So although a very short hop, you should be reporting when transitioning into JSRW, then reverting back to 124.800 for your approach into Kroon.
Cheers, John
John Comley
