HELMET ADVISE
GOATMAN
HELMET ADVISE
Postby GOATMAN » Fri Mar 14, 2014 12:22 pm
NEED SOME INFO ON HELMETS,I'VE BEEN FLYING GYROCOPTER ,PAX COMPLAINS ABOUT THE WIND
AT THE BACK,DOES A HELMET(WITH VIZER) WILL BETTER THE SITUATION AND WILL IT IMPROOF OUR COMMUNICATION.
DOES THESE HELMETS WORK ON ZULU HEADSETS AND IF WHAT IS THE HELMET TO BUY? :(
Re: HELMET ADVISE
Postby Tumbleweed » Fri Mar 14, 2014 1:00 pm
Fit Zulu's after market plastic bib which fastens to the bottom of the visor.
PeterGrant
Re: HELMET ADVISE
Postby PeterGrant » Fri Mar 14, 2014 2:20 pm
Hi Goatman,
A helmet with visor keeps the wind off your face and from blowing on the microphone but does not do much for engine noise.
The bib extends your visor and helps to keep more wind out of your face.
For that you need to fit a big fat sponge over the microphone.
Google micro-light helmets in SA and you will find helmets with cut-outs around the ears that can be worn with most headphones.
Peter.
GOATMAN
Re: HELMET ADVISE
Postby GOATMAN » Fri Mar 14, 2014 2:33 pm
Thanx Guys appreciate (^^)
