Sycamore Accident
CrashLab
Slow starter
Sycamore Accident
Postby CrashLab » Mon Nov 18, 2013 8:31 am
Good Day All
I am currently involved with the accident investigation on a Sycamore gyrocopter - ZU-EUI in South Africa.
The dual brackets attaching the rotor-head assembly (in this case a 33ft aluminium rotor conversion from a 30ft) fractured in flight. The pilot and passenger survived the forced landing. I found the brackets/plates to be of inferior quality, not only when compared to an intact 'reference set', but also for this (crucial) application. I also noted that no part/serial/batch numbers on these brackets, not on the failed nor on the new. Can anyone on this forum supply me with these number/s and if any exist? Did anyone ever experienced the same type of failure/s?
Coenraad Snyman
Physical Metallurgist
Aircraft Accident Investigator (Coenraad@crashlab.co.za)
Re: Sycamore Accident
Postby nicow » Mon Nov 18, 2013 10:11 am
CrashLab wrote:Good Day All
Coenraad Snyman
They are very lucky to be alive...That was fast thinking and lots off experience that helped.
leprechaun
Postby leprechaun » Thu Nov 21, 2013 1:20 pm
Eish , pleased to hear they survived , reminds of the accident a few years ago at Rhino Park when the rotor came off ???? , dont know them that well Leprechaun :shock:
leprechaun
Postby leprechaun » Thu Nov 21, 2013 1:24 pm
Hi Coenrad you may want to contact Glenn Meyer at Springs , 083 662 6565, he does services on Gyros , hope you come right and resolve the issue leprechaun :shock:
crazydoc
Postby crazydoc » Fri Nov 22, 2013 2:05 pm
Sounds like a close call.
How did it effect rotor function and flight?
Steve_SP
Postby Steve_SP » Fri Nov 22, 2013 8:48 pm
Hi Coenraad
In this a fairly recent accident - I'm not aware of an accident with ZU-EUI.
The SA CAA accident briefs only go up to Sept 2013 - would this incident be more recent ? I couldn't find anything on the broader WWW either.
If possible can you confirm the the basic info - date & location - thank you.
Steve
http://gyroaccidents.blogspot.co.uk/
