Converting Trike wing to Topless
- Junkie
- The sky is all mine
- Location: Killed in microlight accident 23rd December 2006
Anyone contemplated this yet - talk around the camp fire suggests some want to use existing sail and build their own
Seems possible to replace the Lower side main cables with struts that should then do away with top side mains, but how does one ensure keel stiffness and the trailing edge luff, etc is maintained, etc
.. maybe Jen can comment on this
J.U.N.K.I.E 's
No credit / No returns
- Junkie
Hee hee
also known as a "Standing Pipe" but my luck the darn thing would'nt stop leakin
Damn fine idea FAWgie.. if only i could lay my hands on that RV o' yours you can be friggin sure id barnstorm with it
.. always had an urge to fly arse-over- eels and was always trying to do this in gliders back in the good/bad ol days (made my instructors sick more than a few times) .. sadly not going to happen in a trike - Topless or not!
Practically speakin we know theres a lot going for topless - hangering, easy derig, fold back wings for trailering without removing, peformance, etc
The norm with the Capies as always is to "investi-bate" about such things alla time and some of us are daft enuf to try stuff like this (moi excluded)
I think well let this one die a quite dignified death anyway an give Jen a call to see if its worth the hassle
J.U.N.K.I.E 's
Jenya's topless wing has a thick cable running inside the aluminium strut (for safety).
He can convert existing wings to topless but I think it will be more hassles to get CAA approval than to do the mod.
The topless wing is very fast! It doesn't stall either (2 x 95kg pax and pushing bar against the profile tube). The whole wing felt very rigid and secure to me. I definetely think it is the way to go if you want a new wing....
- Junkie
Tx Miskiet:
Can appreciate the safety cable.. how is the sail movement "billow shift" taken care of or is the whole thing more rigid ?
Eagerly await any info - there are of course a number of imports available, at a price (& rising) ..
.. which way to go now is the question
- local / import
- larger / small wing
- RST or conventional span
- effective range 35 - 90mph
hhhmmmmm ...
:D :D
- local / import
hhhmmmmm ...
:D :D
J.U.N.K.I.E 's
Hi Junkie,
I met alanmack at Microland today. He has a topless wing from Jenya. Unfortunately the wing was folded up, so I could not check it out in its full glory. Alan seems to be quite happy with it. For more info maybe pm him.
I am still waiting with baited breath to see the wing that Jenya is converting to topless. should be finished soon.
You mention that there are a couple of imports available. So far I could only find the italian Hazzard. Are there any others available?
Arnulf
Arnulf
What about the "North Wing" topless?Arnulf wrote:Hi Junkie,
Arnulf
