Important factors about flying.
Bennie Vorster
Postby Bennie Vorster » Mon Jun 12, 2006 7:02 pm
http://www.start-flying.com/index.htm
http://www.start-flying.com/new%20site/ ... _micro.htm
http://www.aopa.org/asf/online_courses/
http://www.units.muohio.edu/dragonfly/f ... ndex.htmlx
http://www.ultralightnews.com/pilotslou ... flight.htm
viewtopic.php?t=2237
http://atschool.eduweb.co.uk/radgeog/cl ... chart.html
http://www.eos.tuwien.ac.at/Oeko/Teachi ... /id188.htm
http://www.toandfromtheairport.com/ligh ... /FlySA.htm
http://www.jankelow.co.za/X_Files%5CX_P ... _15305.pdf
http://www.mountainflying.com/must1.htm
Quote: skybound
Ensure you are legal !
(b) if the aircraft is engaged in a domestic flight -
(i) the certificate of registration;
(ii) the certificate of airworthiness (or authority to fly);
(iii) the appropriate licence of each flight crew member;
(iv) the aircraft radio station licence;
(v) the certificate of release to service (if type certified);
(vi) the aircraft flight manual referred to in regulation 91.03.2 or an equivalent document;
(vii) the mass and balance report;
(viii) the flight folio;
(ix) the MEL, if applicable;
(x) the noise certificate, if such certificate has been issued for the type of aircraft; and
(xi) the list of visual signals for use by intercepting and intercepted aircraft.
Hope it helps :wink:
Last edited by Bennie Vorster on Fri Jun 30, 2006 9:12 pm, edited 16 times in total.
Bennie Vorster
083 277 5110
Arnulf
Postby Arnulf » Mon Jun 12, 2006 7:41 pm
Uitstekend Bennie !!!!
Bennie Vorster
Re: Start Flying Briefings
Postby Bennie Vorster » Mon Jun 12, 2006 7:51 pm
TX :wink:
Bennie Vorster
083 277 5110
Bacchus
Postby Bacchus » Mon Jun 12, 2006 9:00 pm
Bennie
Dis nou een van die beter "posts" wat ek in n lang tyd gesien het.
Netjies man.
ZU-GFC COBRA
Chaz
STICKY !!
Postby Chaz » Tue Jun 13, 2006 9:16 am
Just a suggestion for the moderators but can this topic that Bennie posted here be made sticky so as always to remain on top of the first page. (hope im explaining myself right here).
I think it is very informative and what i liked best is it's simplictiy of carrying over the message. Sometimes i think rookie pilots get intimidated with "NASA" talk.
Thank's a lot Bennie found it very interesting.
Your's in Flying 8) 8) 8)
CHAZ
Re: STICKY !!
Postby Morph » Tue Jun 13, 2006 10:07 am
Chaz wrote:Just a suggestion for the moderators but can this topic that Bennie posted here be made sticky so as always to remain on top of the first page.
Chaz,
I have made it a sticky for now. Lets see the activity of this topic. If it stays active I'll leave it as a sticky
Postby Tumbleweed » Wed Jun 14, 2006 7:03 pm
ZU-ANE
Postby ZU-ANE » Wed Jun 14, 2006 8:29 pm
Thanks, very usefull
Bennie Vorster
Postby Bennie Vorster » Sat Jun 17, 2006 4:17 pm
Delta VV wrote:http://www.auf.asn.au/safety_index.html
Refresher's course.
=D* =D* =D* =D* =D*
Bennie Vorster
083 277 5110
