Dual transmit with a Chatterbox system
ZULU1
Postby ZULU1 » Wed Jul 24, 2013 12:28 pm
I am posting this under Training as the requirement for Dual transmit is for Instructors. All chatterboxes have this capability. Remove the 4 screws on the front face, inside is a small slide switch, this switch selects either dual or pilot transmit.
Simple !
Re: Dual transmit with a Chatterbox system
Postby John Boucher » Thu Jul 25, 2013 1:20 pm
Hmmmm, thanks for that Paul.
Needed the function the other day with my flight test....
ZULU1
Postby ZULU1 » Fri Aug 02, 2013 8:41 am
I attach a picture of the twin PTT system that we have always made but also never told anyone. One ptt goes on the seat frame and the other is used as normal on the bar. It takes a standard ptt that we have always made. To install, remove the top cover, unscrew the pcb and remove the rj9 plug on the pcb and replace. The second PTT may be removed as may be the primary with a simple plug.
leprechaun
Postby leprechaun » Mon Feb 10, 2014 3:19 pm
Hi Paul , your present PTT buttons need some urgent attention , - the glue used to secure the velcro ## is absolutely useless as it come loose in no time , I had one do this the weekend again , pse give immediate attention Alex (leprechaun )
ZULU1
Postby ZULU1 » Mon Feb 10, 2014 3:58 pm
Thanks Alex, wasnt aware but will sort it...thanks for the feedback.
Postby nicow » Mon Feb 10, 2014 4:24 pm
ZULU1 wrote:Thanks Alex, wasnt aware but will sort it...thanks for the feedback.
Martinvt
Postby Martinvt » Mon Feb 10, 2014 7:03 pm
Hi Paul,
I have the same problem.
Martin van Tonder
Aerotrike Safari
ZU-CIE
