Best Oil for Rotax 912 UL ?
Pietb
Postby Pietb » Wed Jul 10, 2013 9:39 am
I was told by an AMO to put in or top up with Shell AX 7 (motorcycle oil) but struggle to get or does anyone know where to get some ?
I can get HX 7 but apparenty not recommended
Any other oil that can be used or recommended ??
I see on the Rotax website that Aeroshell Sport Plus 4 is highly recommended but (R193 / Lt at a local shop at Rand :shock:).
The guys from a Shell depot informed me that its not yet available in SA ?? :shock:
Any advise as I only need to top up please ? (only about 500 ml)
Piet
Jab ZU-FDZ
MMW
Re: Best Oil for Rotax 912 UL ?
Postby MMW » Wed Jul 10, 2013 10:13 am
Hi Piet - I recently purchased Aeroshell plus 4 from Boksburg shell depot for R110 / liter, i think the place called Atlas shell, but will double check and let you know
Mark Wheeler
Thatchman
Postby Thatchman » Wed Jul 10, 2013 11:37 am
I use Motul 5100 in the 912ULS. Have used it for years. Also purchased from bike shop.
ZU - forePLaY
Pietb
Postby Pietb » Wed Jul 10, 2013 2:55 pm
Thank you for the replies guys !
Thanx Mark....I`ll be waiting for your feedback.
piet
Jab ZU-FDZ
Postby Boet » Wed Jul 10, 2013 8:34 pm
Wat van Total Quartz 5000, 20W50. Ek gebruik dit al jarre lank in al my voertuie, sonder enige probleme.
Turbi se Lyc 0320 gebruik dit ook. Wat se die experts? :roll:
JvTonder
Postby JvTonder » Thu Jul 11, 2013 9:25 am
Boet wrote:Wat van Total Quartz 5000, 20W50. Ek gebruik dit al jarre lank in al my voertuie, sonder enige probleme.
Oom Boet ek kan nou nie onthou nie maar die Quartz 5000 is mos nie 'n motorfiets olie nie of is dit? Die 912 het juis 'n goeie motorfiets olie nodig vir die ratkas. Ek het toetse laat doen toe Shell VSX van die mark af is en behalwe vir die ax7 is Castrol Activo wat 'n 10w40 is ook 'n baie goeie keuse, gebruik dit in al my motorfietse en het dit ook gebruik, ken ook 'n paar vriende wat dit in hulle 912's gebruik sonder probleme.
Die groot ding is om te doen wat die boek sê:"Motorcycle oil of registered brand with gear additives. If using aircraft engine oil; then only blended one." en " API classification "SG" or higher"
Hoop dit help bietjie om ding nog meer deurmekaar te maak :lol:
Flying feeds the soul!
Pietb
Postby Pietb » Thu Jul 11, 2013 9:41 am
Dankie manne vir al die info.
Ek het egter reg gekom Jaco.
Mark het vir my die Aeroshell Sport Plus 4 wat deur Rotax aanbeveel in die hande gekry by `n depot in Boksburg genaamd Atlas Oil.
Groetnis
Jab ZU-FDZ
Postby Boet » Thu Jul 11, 2013 9:54 am
Moenie jou 912 stadiger as 200 rpm laat idle nie, dan knetter en raas die ratkas, nie goed nie. Ek koop liewer remskoene as om n ratkas te overhaul! Maak nie saak watter soort olie jy gebruik nie, onder 2000rpm RAAS hy. ## ## ## ##
Pietb
Postby Pietb » Thu Jul 11, 2013 10:03 am
Dankie Boet.
Jab ZU-FDZ
KFA
Postby KFA » Thu Jul 11, 2013 9:04 pm
This is the right stuff. I have some in stock and can get more if you want. Will have to check the price but is readily available.
SHELL ADVANCE 4T AX7
SYNTHETIC TECHNOLOGY 4-STROKE MOTORCYCLE ENGINE OIL
RECOMMENDED REPLACEMENT FOR SHELL ADVANCE VSX 4
Shell Advance 4T AX7 with R.C.E.* Technology is a unique, synthetic technology lubricant ideal for high performance motorbikes. Demanding engines deliver high power and torque and require oil performance reliability under these stressful conditions. Their riders expect the enjoyment and excitement of advanced ride comfort.
Shell Advance’s R.C.E.* Technology helps your bike perform to its peak potential, making it responsive to your slightest touch.
APPLICATIONS
n High-performance air and water-cooled four-stroke motorcycle engines, including those with integral gearboxes and wet clutches.
n Motorcycle gearboxes that must be lubricated by engine oils, including some gearboxes present in two-stroke bikes and scooters.
n Offers enhanced performance for smaller motorbikes, underbones and mopeds.
SPECIFICATIONS, APPROVALS
AND RECOMMENDATIONS
THE PRODUCT IS AVAILABLE IN TWO DIFFERENT VISCOSITY GRADES:
n SAE J 300 10W-40 and 15W-50.
EXCEEDS THE INTERNATIONAL SPECIFICATIONS OF:
n API SL, JASO MA2.
MEETS THE REQUIREMENTS OF:
n All Japanese, European, Indian and Chinese motorcycle manufacturers.
Turbo
Postby Turbo » Thu Aug 08, 2013 11:04 pm
Rotax call for an API rating of SG, this was discontinued in 1996, there are pseudos in the market which are fully synthetic and usually found in bike engines.
The reason the 912 wants a bike engine is because a bike engines oil is supplied the bikes gearbox aswell - the reduction drive is a gearbox and shares the engines oil.
I uh direct from FUCHS which is my next door neighbor, their product is a true SG API rated oil, and is called silkolene race -- R810 for 10 liters, I buy it in a case which is 10litres.
It is red in color and works like a dream!
Maathai Wangari
Postby Maathai Wangari » Sat Aug 17, 2013 8:33 am
I am using Motul 5100 in the 912ULS. I have good experience with it and there is still no complaint for Motul 5100. Its best and affordable.
AWACS
Postby AWACS » Tue Sep 17, 2013 7:39 pm
Mogul 5100 not to be used in 912 - refer to Rotax service instruction
SI-912-016 R2
Previously recommended oil but not anymore due to changes in the oil formulation.
Careful... ## !
Raptor 582
ZU-Sling 2
AWACS
Postby AWACS » Wed Sep 25, 2013 3:40 pm
The latest Rotax SI on the oil debate.
http://www.rotax-aircraft-engines.com/p ... d04899.pdf
Raptor 582
ZU-Sling 2
Turbo
Postby Turbo » Fri Sep 27, 2013 8:43 pm
AG okes - just use sunflower oil --- it works for our taxis on the roads, why cant it work for our planes!? and the taxi bosses also have a special cardboard brake pad too!
lekker cheap!
