http://www.electraflyer.com/
ElectraFlyer Trike
What if we could fly in the open air with very little sound other than the rushing air? How close would that be to a magic carpet ride? One that we could steer safely wherever we want, whenever we want. It is a dream we never really believed could come true.
But The Dream Has Come True! You can fly this way any time you want, with the ElectraFlyer!
Experience Pure Electric Flight
The nearly silent electric motor and the ultra quiet, slow turning propeller make this joyous dream a reality!
Download Brochure
Watch the ElectraFlyer Trike in flight video
Technical Details
Motor: Low RPM, high torque unit. 26 pounds, 18HP 90% efficient at cruise.
Max Thrust: Direct Drive - 53" Prop, 140 lbs, with reduction drive 1800RPM, 63" Prop 155 lbs.
Controller: Pulse Width Modulation electronic speed control for highest efficiency.
Battery Packs: Custom built lithium-ion polymer for highest capacity per weight (power density) High discharge rate cells for full power takeoff and climb. Choose 2.6kwh to 5.6kwh capacity depending on your use.
Flight Duration: Up to Two Hours Depending on Battery Pack Chosen, Total Weight and Efficiency of the Wing - 1 to 1.5 Hour Flights Most Common
Weight: Trike with motor, controller and gauges
Largest battery pack (5.6kwh)
Stratus wing
A true legal part 103 ultralight even with largest pack.
85 lbs (39 kg)
78 lbs (35 kg)
84 lbs (38 kg)
247 lbs (112 kg)
Electric Trikes
Electric Trikes
ZU DZG
