hi
I need to know what will be the best spark plug for this engine
NGK BR8ES
OR
NGK BPR8ES (it looks a bit longer than above type)
What is the difference?
Leon
spark plugs on a 503
ZU-ALW
Hanger 5-7
Microland
120.35
Hanger 5-7
Microland
120.35
- Wargames
Re: spark plugs on a 503
Hi Leon,
Operating Manual says BR8ES.
Dont know the other plug, but rather stay with what ROTAX has defined for the motor.
Dirk
Dirk
- Duck Rogers
Great thank you for your help guys
Leon
Leon
ZU-ALW
Hanger 5-7
Microland
120.35
Hanger 5-7
Microland
120.35
- Kalahari
- Survived first engine out
Hi DR
Thanks for the interesting info.
Is the sheet with plug nrs that you supplied only applicable to NGK spark plugs?
Arrogance and rudeness are the training wheels on the bicycle of life for those who can not keep their balance without it!
- Duck Rogers
Yes.........you will need to look up the equivalents if you want other manufacturersKalahari wrote:Hi DR
- V
- Whats the right frequency?
Slightly relevant info: plug with resistor ('R') or not. I've been shown once the inside of NGK plugs with resistor and without. In the non-resistor type the connection to the top (outer) terminal is a flimsy little wire that can actually break loose from vibration quite easily. These plugs have a much higher failure ratio for this reason. The resistor type is much-much more robust.
Cheers,
V.
Cheers,
V.
