What Now????
What Now????
Postby Blue Max » Sun Apr 28, 2013 5:59 pm
Wat doen n ou met n 582 engine wat 1000 ure op het.??? :? :? :?
Dobbs
Re: What Now????
Postby Dobbs » Sun Apr 28, 2013 6:56 pm
Not sure what the question is about.
Local legislation now allows on condition - if you have an AP that is able to do the necessary checks, compression, big end, small end, crank bearings etc - if all within spec you are good to go. However, a 582 at 1 000 hours has either been previously overhauled or may well be in need of an overhaul, but as far as I am aware, there is no magic number that this has to happen at.
Re: What Now????
Postby nicow » Mon Apr 29, 2013 8:04 am
Blue Max wrote:Wat doen n ou met n 582 engine wat 1000 ure op het.??? :? :? :?
Gebruik hom tot 1200 ure,en laat 'n AP hom nagaan.
ZS-NEL
Re: What Now????
Postby ZS-NEL » Mon Apr 29, 2013 5:45 pm
Jy sit vinnig nog 1000 ure op Namibia toe en terug.
Re: What Now????
Postby Bundy » Tue Apr 30, 2013 5:47 am
Oom Paul, have your AP take a good look at the engine before you leave...if all in spec then there is no reason why you cant fly it to the 1200hr mark at least. You just really dont want to get stuck in "fokweetwaarfontein" waiting for your trailer! :(
When you get back, chat to someone like Alex Rudd and see if there is a "trade in option" avalable? He has quite a collection now of 582's of various ages and I'm sure he has an engine that will suit your needs.
1000 hrs is definately on the older side so if I was you I'd be preparing for a major overhaul or replacement soon.
Good Luck (^^)
mulderpm
Re: What Now????
Postby mulderpm » Tue Apr 30, 2013 8:11 am
Blue Max wrote:8)
My Rotex have 900 hrs on the clock.
I bought it at 320 hrs.
I use any available mineral two stroke oil.
Whether it is mobil, caltex, lawnmower, chainsaw, outboard or what have you..As long as it is two-stroke oil.
Have a nice day. ## ## ##
Have an AP check out your engine. Maybe even, as a precautionary in preparation for your 2 month Namibian odyssey, insist on a top end overhaul. i.e. Decoke, new rings, new gudgeon pins & new small end roller bearings. Costs about R5 000. Some AP's recommend this overhaul at 300 hrs. FABA's school did 1200 Hrs & 1400 hrs with their training 582's and recently replaced them as a precaution. At Petit the instructor had a crank failure at 310 hrs.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
Re: What Now????
Postby Blue Max » Wed May 01, 2013 11:03 pm
vhpy
Dankie manne.
Ek sien die ouens daar in Amerika ry met bote wat op die water 'ski' met engines wat soos ons trike engines lyk..
Miskien as ek my trike lisensie gaan inhandig eendag kan ek so n boot bou.. **
