Hi guys,
Anyone know where to get one of those tools to crimp Nicopress cable sleeves?
Aircraft Spruce sells them, but they are ..... [Cough!] .... expensive.
Nicopress Tool
- bobthebuilder
Nicopress Tool
Byron Kirkland
- ZULU1
Re: Nicopress Tool
Try three d agencies dont have contact details but behind Hirschs in Durban..
Re: Nicopress Tool
I saw one at Media Hydraulics last week for around R2000...bobthebuilder wrote:Hi guys,
If you only need to do a few cables, this $20 one from Spruce is probably the best bet:
http://www.aircraftspruce.com/pages/to/ ... ngtool.php
See here to see it in action:
http://www.eaavideo.org/video.aspx?v=2293635648001
(You can also watch the other 3 recent Hints for Homebuilders videos - all on swaging cables.
- bobthebuilder
- KFA
Re: Nicopress Tool
I keep stock of those
Re: Nicopress Tool
The $20 version is a lot easier to use than the big handled expensive affair. Also the crimps are always in spec. as there is no lever action.
Roy
Roy
- Duck Rogers
Re: Nicopress Tool
Hey B........you can bum mine for a while if you want. I have the $20 Aircraft Spruce one...bobthebuilder wrote:Hi guys,
- bobthebuilder
Re: Nicopress Tool
Many thanks Duck, but I ordered both sizes from Spruce in the States.
Byron Kirkland
Re: Nicopress Tool
Has anyone used the $20 nicopress tool to crimp 1/8 sleeves as I am also planning on ordering this tool in the near future?
I saw it mentioned that to do the 1/8 nico you need to do a centre crimp first then the thimble end and then the tail end but how would this work in the $20 tool??
Thanks in advance for advice
Raymond
Raymond
Re: Nicopress Tool
The simple answer for 1/8th (3mm) cable is "No problem with the $20 tool".The sleeve length is the same as the width of the tool, so it is easy to centre the sleeve in the tool. The side crimps are a little more tricky, what you need to do is to ensure that the edge of the bit that does the crimping is just within the sleeve so that you get a full crimp but which does not extend over the middle crimp. Take your time and see that you have plenty of light to see by. The bolts don't need much force to tighten down.
Have fun
Have fun
Re: Nicopress Tool
Thanks for this info, crimp tool on order
