Taildraggers to Nylstroom 19-21 July 2013
- KFA
Re: Taildraggers to Nylstroom 19-21 July 2013
Ons is Vrydag middag daar.
Heel tyd SPEELTYD
Balls to the wall
Balls to the wall
- Tribal Croc
Ek sal so net voor 8 daar wees
Potties Patrollie sal ook vroeg saterdag oggend daar wees.....
Kan nie wag nie....
Kan nie wag nie....
Martin van Tonder
Aerotrike Safari
ZU-CIE
Aerotrike Safari
ZU-CIE
Wat se die slim weer mense (Thys)
Sal so 9uur daar wees
- thys bas
- I hate bird strikes
Ek weet niks van weervoorspelling af nie, behalwe dat dit gevaarlik is om te probeer, selfs baie meer gevaarlik as om in los formasie te vlieg Manne soos FAPE en Kloot Piloot is eintlik die regte weer-mense. Ek voorspel niks, vertel net wat ek gesien het
I had a look at two met-data websites: freemeteo.com as well as yr.no. They use different mathematical models to predict weather. Unfortunately SAweather has become totally useless for us slow and low flyers.
Freemeteo.com expects Saturday to be fairly windy in Pretoria, WNW @ 10Knts. Day temperature about 15 degrees and partly cloudy. Nylstroom is expected to be much better with the Wind WSW @ 5Knts and max temp 19 degrees, no cloud. For Sunday they expect wind of about 7Knts NE and temp 15 degrees partly cloudy in Pretoria and wind about NE @ 7Knts and temp 17 degrees in sunshine at Nylstroom. (Max values)
YR.NO expects even better flying weather for the weekend with the wind Saturday morning in Pretoria WNW @ 2Knts and afternoon WNW @ 11Knts and max temp 17 degrees and sunny skies. For Nylstroom they expect a wind of NW @ 4Knts in the morning tuning SW @4Knts in the afternoon on Saturday. Sunshine all day with max 19 degrees and night temp 8 to 10 degrees around the braai fire. On Sunday they expect a wind SW @ 4 Knts and sunshine with max temp at 19 degrees for us to depart in and we can land in Pretoria expecting 7Knts ENE.
Not too bad, better in Nylstroom, as always. Rather chilly in the evening, so bring something hot The two expectations are more or less the same, predicted in worlds apart, so they should not be too far off. Bring sun block and hat.
Be careful of fog early morning if the wind is calm. Wind from east always brings in moisture.
Be aware of carb ice in OAT's of around 20 degrees. The carburettor temp is often about 20 degrees lower than ambient, at certain settings, like on the decent to Nylstroom and about two million other aircraft going the same way and clogging the RT frequency and us forgetting about ice forming between plus 4 degrees and minus 2 degrees!
Fly safe people and FOCUS. it's going to be great!
- KFA
This one is very accurate, I use it every day
ORTIA - http://www.windguru.cz/int/index.php?sc=398171
Nylstroom - http://www.windguru.cz/int/index.php?sc=449429
Helllllll gelukkig het ek nie vir n voledige weer verslag gevra nie
- thys bas
Jaaaa, pasop wat jy vra!! JUST GO!Goose wrote:Helllllll gelukkig het ek nie vir n voledige weer verslag gevra nie
Dankie Stefan, Windguru is ook goed, jy moet my Saterdag wys hoe dit werk asb ,die Safari EN windguru
Magents, the NOTAM for Nylstroom has been officially published, ................. but for you guys it is old news
If you okes in gauteng can close those fridges it will be better here for us. It was cold today I even had to put on a short sleeve jacket
All set and waiting for you all
Balls to the wall
Balls to the wall
- thys bas
Stefan windguru is really good. It predicts the same for the weekend . FAPE mentioned some time ago that if one looks at three different site models and two predicts the same, the chances are very good that the predicted weather will prevail. Now we have three models predicting more or less the same weather for the weekend. Thanks for suggesting the third oneKFA wrote:This one is very accurate, I use it every day
So early up for the pilots and pax who plan to depart for FANY on Saturday and back to Gauteng mid morning on Sunday to avoid wind?
Sorry AVGAS, we have to open the door to fly out. Sien jou Saterdagavgas wrote:If you okes in gauteng can close those fridges it will be better here for us. It was cold today I even had to put on a short sleeve jacket
Great weather this morning
Balls to the wall
Balls to the wall
I am now off to the airfield
See you later
Richard
See you later
Richard
Balls to the wall
Balls to the wall
Ons is gerefuel,gepreflight,gelaai,en wag vir daglig om op te styg...5 trikes vanaf Potties
vliegskool@hotmail.com
ZU-AWA
ZU-DMM
ZU-AJO
ZU-AWF
ZU-BAI
ZS-WOR
ZU-TCT
ZU-DOD
ZU-CIE
ZU-BIW
ZU-AWA
ZU-DMM
ZU-AJO
ZU-AWF
ZU-BAI
ZS-WOR
ZU-TCT
ZU-DOD
ZU-CIE
ZU-BIW
WOW,what a day
See you all next year again
ZU-AWA
ZU-DMM
ZU-AJO
ZU-AWF
ZU-BAI
ZS-WOR
ZU-TCT
ZU-DOD
ZU-CIE
ZU-BIW
ZU-AWA
ZU-DMM
ZU-AJO
ZU-AWF
ZU-BAI
ZS-WOR
ZU-TCT
ZU-DOD
ZU-CIE
ZU-BIW
Users browsing this forum: No registered users and 68 guests
