Aircraft Log Book
gertcoetzee
Aircraft Log Book
Postby gertcoetzee » Mon Mar 18, 2013 8:28 am
Can anyone advice where I can buy an Aircraft Log Book (the big blue one, I think)
None at Fisantekraal (Louis) or at Stelfly's shop.
justin.schoeman
Re: Aircraft Log Book
Postby justin.schoeman » Mon Mar 18, 2013 9:55 am
You can order them from the government printers:
http://www.gpwonline.co.za/Pages/default.aspx
John.com
Postby John.com » Mon Mar 18, 2013 10:37 am
justin.schoeman wrote:You can order them from the government printers:
Yes, this is what is available from GPW:
Unfortunately they no longer print logbooks as A5 which means you have to use an A4 format!
However, for my liking it is far easier to go along to one of the aviation supply shops at any of the airports, such as Wings & Thinks (Lanseria or Grand Central) or Comet at Rand.
John Comley
Magaliesberg, South Africa
Gadget
Postby Gadget » Wed Mar 20, 2013 11:39 am
Check with Sean Curran.
If there is grass between your toes , you're flying to low.....
If ever in doubt about flying - drink a beer.
That will give you at least 8 hours to think about it some more.
ZU-EPH Bushbaby Explorer 912UL (Morph built)
Sad-Ham
Postby Sad-Ham » Wed Mar 20, 2013 3:02 pm
Commet Aviation at Rand Airport
Aquilla II ZU-DJS
Wingfield - 124.8
gertcoetzee
Postby gertcoetzee » Thu Mar 21, 2013 2:10 pm
Not one of the aviation shops in CT had it, so I had to order from Gov Printers. Can only guess when I will get it. In the mean time all paperwork in order (sans said copy of Aircraft Log Book), and no reply from RAASA as to what I could do about getting an ATF without.
