EGT Rotax 582
cjkrit
EGT Rotax 582
Postby cjkrit » Tue Feb 26, 2013 10:26 am
The temps [EGT] on my Rotax 582 Bluetop all of a sudden differ a lot - as much as 490 reading on the one and 1050 reading on the other one.
Possible causes?
Where must i start with fault finding?
Christo kritzinger
Re: EGT Rotax 582
Postby Morph » Wed Feb 27, 2013 8:12 am
Your EGT is controlled by your fuel/air mix. Richer mix lower temps, leaner mix higher temps. If you take your plug out on that piston and it is burning white/grey then it is definitely a leaner mix. It should be dark chocolate brown.
The hot temp is excessive and will result in a hole burnt in your piston. Don't fly with it like that.
I would suggest there is a blockage in one of the jets of your carb on that piston. A good clean should solve that problem.
cjkrit
Re: EGT Rotax 582
Postby cjkrit » Wed Feb 27, 2013 8:36 am
Morph,
I must add that these are Fahrenheit temps. So the one cylinder is actually running very cold.[normal 1050-1100 degrees F]
Could it be a faulty temp probe/censor?
Thanks for the reply.
Re: EGT Rotax 582
Postby Morph » Wed Feb 27, 2013 9:01 am
ok,
then it is either very rich on the cool piston or a faulty sensor, check the plug, if brown, ok, if black and oily not.
It is probably the sensor, I have had low cool readings from broken wires and sensors
Mc Guyver
Re: EGT Rotax 582
Postby Mc Guyver » Wed Feb 27, 2013 11:19 am
Swap your leads around and if the reading moves with the change, you then know it is the probe that is faulty.
That would be your quickest route to try find the problem.
cjkrit
Re: EGT Rotax 582
Postby cjkrit » Wed Feb 27, 2013 6:49 pm
I did swap the sensors - faulty sensor.
Thanks for the advice - much appreciated. vhpy vhpy
Next question - Where do I buy a new sensor?
HENNING JOHAN
Re: EGT Rotax 582
Postby HENNING JOHAN » Wed Feb 27, 2013 8:01 pm
cjkrit wrote:I did swap the sensors - faulty sensor.
Ask Alex Rudd.Leprachaun on the forum.
Re: EGT Rotax 582
Postby Morph » Thu Feb 28, 2013 7:25 am
You can also get them from MGL in Somerset West 021 855 1383
Be careful when you take the old one out, they can be really tight and with enough force they can snap off
cjkrit
Re: EGT Rotax 582
Postby cjkrit » Sun Mar 03, 2013 10:51 am
This is what mine look like.
cjkrit
Re: EGT Rotax 582
Postby cjkrit » Tue Mar 05, 2013 7:20 am
Anybody with a contact number for Alex Rudd [leprachaun]?
Sms me the number to 0825760214 please.
