Water for Rotax 582?
Loco
Postby Loco » Tue Nov 06, 2012 7:30 pm
Hi guys whats the correct water and additives to use for a 582?
Still or distilled?
What brand antifreeze you use and how much?
Ant
Anthony Hugo
Crosswinds
Re: Water for Rotax 582?
Postby nicow » Tue Nov 06, 2012 8:15 pm
Ant
Gebruik battery water.
Loco
Postby Loco » Tue Nov 06, 2012 8:21 pm
nicow wrote:Ant
Dankie Nico so dis distilled water?
Geen anti freeze of iets anders by nie?
Anthony Hugo
Crosswinds
kloot piloot
Postby kloot piloot » Tue Nov 06, 2012 9:53 pm
anthonyhugo wrote:Geen anti freeze of iets anders by nie?
nicow wrote:AntGebruik battery water.
Dankie Nico so dis distilled water?Geen anti freeze of iets anders by nie?
Definitief anti-freeze ook.
My Rotax manual is nie nou by my nie, maar jy benodig heelwat anti-freeze in die mengsel.
En soos wat die debat oor 2-slag olie gaan, is daar blykbaar ook spesifieke anti-freeze wat jy moet / en nie moet gebruik.
Private Message gou vir Duckrodger op die forum. Hy is Wisdom in motion.
Roel Jansen
ZU-IAR powered by BMW 1200
Nacho
Postby Nacho » Wed Nov 07, 2012 3:27 pm
Maak maar net seker die antifreeze kan werk met allumenium. Volg dan die details op die bottel.
Ek kry gewoontlik by die motorfiets winkel a kwaliteit antifreeze.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
mulderpm
Postby mulderpm » Sun Jan 06, 2013 6:33 pm
Ant, according to Rotax recommended liquids and fluids, any antifreeze that is silicate free and mixed 50 50 with distilled water. puff I flushed with 5 liters of distiller water and then filled with Castrol SF (silicate free) pre mix, pink in color. Done 100 hrs now and temp is between 60 & 75. (^^) mostly 65.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
Postby Duck Rogers » Sun Jan 06, 2013 10:22 pm
To cut a very long story short - must be compatible with aluminium (most are nowadays anyway) and NOT more than 50/50 mix.
If you put too much antifreeze in you can actually INCREASE the temperature. Remember, its called "antifreeze" We do not have those kind of temperatures in SA that freeze up engine blocks etc. I usually only put about 30% antifreeze.
If you experience higher than normal temps, try reducing the mix.
There's a saying that goes "less is more".
Postby John Boucher » Sat Jan 12, 2013 11:58 am
The "anti freeze" or "coolant additive" also changes (increase) the boiling point of water (changing from liquid to gaseous stage)
