Serious Problems.!!!
Postby Blue Max » Fri Nov 02, 2012 8:56 pm
I need a piece of alluminium grade 6061 ( T 6 Extruded).
1.3mx50mmx76mmx3mm rectangular tubing..
This is is to replace a component that was dammadge when I did the unfortunate landing with my T Birrd last weekend... :x
I have been phoning all over the country to try and get hold of this.
Trevor Davies, the fudie in this department, has no stock at the moment. :roll:
Maybe you know some-one who is in the aviation repairs department who can sell me a piece of this type of alluminium.!!!!
Plse, if you can help I will be very gratefull... My aerie is grounded only for this stupid piece of Allu.!!! (**)
witwillem
Re: Serious Problems.!!!
Postby witwillem » Fri Nov 02, 2012 9:30 pm
Hoor by mike ysterman Beukman as hy nie Bettie sal hy se war jy kan kry o825598899 willempie :mrgreen:
kloot piloot
Postby kloot piloot » Fri Nov 02, 2012 9:42 pm
Ek was gister by Yenja. Hy het heelwat aero-alli materiaal. Yenja: nul agt 2 agt 5 3 8239.
Probeer maar.
Roel Jansen
ZU-IAR powered by BMW 1200
ZS-NEL
Postby ZS-NEL » Fri Nov 02, 2012 10:17 pm
Het jy Eurosteel probeer?
http://www.eurosteel.co.za
Postby Boet » Sat Nov 03, 2012 4:36 pm
Het jy Non Ferrous Metals probeer? Hulle het takke in meeste groot stede.
Postby Blue Max » Sat Nov 03, 2012 7:51 pm
vhpy
Tx gentleman, you make me very happy.
:evil:
I have phoned Euro steel and all other major players in the Alu business including alu extruder companies.
Monday I will try GYennia, Solarwings, Ysterman Beukman and Non Ferrous metals..I will also go to some Aviation workshops in Germiston, and, and ,and.
And I will also find out if another buddy of mine could have manage to obtain a piece of this particular Alu from a undisclosed source.!!
In the meantime Trevor Watsenaam tries to organize a piece of this 'difficult to obtain' alu from America...!!!
So you guys can imagine how gatvol I am because there are many substitutes that might even be stronger and other Boer maak n plan, planne that I could bring into action...BUT, because I was so stupid to report this to CAA I have to work to the original specs, and any deviation will cause month,s and month,s of burocratic shit be-ing prescribed to you by you know who!!! ( with no experience.!!!)
Ek is gatvol.
kloot piloot
Postby kloot piloot » Sat Nov 03, 2012 10:50 pm
Patience Bluemax ... patience ...
Maar ek weet hoe dit voel. Volg maar die boek.
Roel Jansen
Folla
Postby Folla » Sun Nov 04, 2012 1:20 am
Try Robor, not sure of the nr.
Folla
Asterix
Postby Asterix » Sun Nov 04, 2012 8:57 am
Vat 'n ou tentpaal en saag hom regte lengte man! :shock: :wink:
Wees maar geduldig oom Polla, darem loop die trike nog! vhpy
bobthebuilder
Postby bobthebuilder » Sun Nov 04, 2012 9:33 am
Should Trevor Davies, as the agent, not support his product?
Ask HIM where he gets the s**t.
Byron Kirkland
Le Pou
Postby Le Pou » Sun Nov 04, 2012 8:49 pm
You won't get 6061 -T6 extrusions from any local supplier. Contact PLACO and ask them to get it from Aircraft Spruce. They get deliveries twice a week. Takes about 1 to 2 weeks from placing of order. I have used PLACO quite a lot . You can also order direct from Aircraft Spruce but I found their delivery charges much more expensive than using PLACO's system.
Good luck!
Roy
Postby Blue Max » Mon Nov 05, 2012 1:10 pm
Le Pou wrote: by Le Pou » Sun Nov 04, 2012 8:49 pm
Good luck!
I agree on this.. will do. Tx everybody..
bobthebuilder
Postby bobthebuilder » Mon Nov 05, 2012 1:37 pm
Maybe contact Hennie from Infinity Aviation. He get shipments in from ASC weekly, and his pricing seems to be a bit more competitive than Placo.
Byron Kirkland
