582 oil reservoir pipe
Loco
Postby Loco » Thu Jul 26, 2012 4:20 pm
Hi guys
I need to replace my 582's oil reservoir pipe
What's the best pipe to use & where can I get it from please
If you know what should the correct inside & outside diameter be please?
Many thanks!
Ant
Anthony Hugo
Crosswinds
bobthebuilder
Re: 582 oil reservoir pipe
Postby bobthebuilder » Thu Jul 26, 2012 4:42 pm
Howzit Ant,
I replaced mine about a year ago, and got the tube from Comet Aviation supplies.
A meter cost over R600.00 (**)
Get the spec from the print on the existing tube, and try Hose Centre in Edenvale. I'm sure that they can provide a direct replacement.
Byron Kirkland
Loco
Postby Loco » Thu Jul 26, 2012 4:50 pm
bobthebuilder wrote:Howzit Ant,
Ouch that's a crazy price hey!? :shock:
Problem is the existing hose is too messed up for me to check the specs on it + it's on the engine currently (oil & all)
Anthony Hugo
Crosswinds
bobthebuilder
Postby bobthebuilder » Thu Jul 26, 2012 6:20 pm
Ant ..... Stand by.
Byron Kirkland
bobthebuilder
Postby bobthebuilder » Thu Jul 26, 2012 6:29 pm
Kay .... Here we go!
CONTI-TCH-OLN- 11x3.5 >NBR/CR< 41/09/31
Byron Kirkland
Leprachaun
Postby Leprachaun » Thu Jul 26, 2012 8:17 pm
I got pipe in me garage , you can get a goodyear from midas for 30,00 per meter Leprachaun
KlapperKnop
Postby KlapperKnop » Thu Jul 26, 2012 8:31 pm
Leprachaun wrote:I got pipe in me garage , you can get a goodyear from midas for 30,00 per meter Leprachaun
Alex, I need to come and see you tomorrow evening; I need the following for the weekend:
-Plugs
-fuel line
-carburettor silicon rubbers
-oil pipe
Regards, Faizel
ZU-DJE
Loco
Postby Loco » Fri Jul 27, 2012 8:34 am
bobthebuilder wrote:Kay .... Here we go!
You are legendary thanks a mil!!! (^^)
Anthony Hugo
Crosswinds
Loco
Postby Loco » Fri Jul 27, 2012 8:35 am
Baie dankie oom Alex sal dit definitief kom haal!
Anthony Hugo
Crosswinds
Taildracula
Postby Taildracula » Fri Jul 27, 2012 9:27 am
and what is the pipe size for the auto-lube system
bobthebuilder
Postby bobthebuilder » Fri Jul 27, 2012 10:20 am
Whats an Auto-Lube?
I don't now thet-onnnne.
Byron Kirkland
Loco
Postby Loco » Fri Jul 27, 2012 10:27 am
Perhaps someone with the knowledge can post here the ALL the correct pipe sizes for a 582 (fuel, oil, coolant, etc.) and which pipe to get for each
Perhaps even where you can get them from at a good price (Midas, Comet, uncle Alex :))?
Someone might find it useful?
Anthony Hugo
Crosswinds
Postby Boet » Sun Jul 29, 2012 10:43 am
Rotax has a bussiness plan of note. I recently needed to replace the cooling hoses on my 912. I can ONLY buy this from Rotax. The hose is odd size. Likewise all the O rings etc. So for the most part, aftermarket, or "Pirate" parts are out. Die wet van Transvaal "geld": Kak of betaal. DIS die wet van Transvaal.
Many years back, I bought some small items from a big aircraft parts concern. The price was out of any reason too expensive. When I complained, I was told: "If you want to fly high, you must pay high." I walked out, highly de moer in, and have not bought a single item from that company ever again. What comes around, goes around. They have since gone belly-up, wich is not surprising, considering their "lovely customer oriented" attitude. :evil:
mulderpm
Postby mulderpm » Thu Aug 02, 2012 12:04 pm
Ant, I bought my pipes and oil seals from a place called Minuli, zero 12 three 77 zero 233 and Seal Centre, zero 12 379 six 17 zero, respectively. They have the original Good Year imperial diameter pipes and seals, at a fraction of the cost. (^^) (^^) They are in the same building in Hermanstad, Pretoria. vhpy
Paul :mrgreen:
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
