Which prop?
- Gadget
- I hate turbulence
Which prop?
Hi.
Ok, so I have spoken to three different people who should know and all three came back with different answers. Now I ask my question here in the hope to eventually figure out what would be the correct propeller for my plane. My problem is that I cannot figure out or get a definitive answer on what diameter prop to get. The suggestions have been from 68" to 72" with a 70" in between. I would appreciate some info from those who have faced this dilemma and found a solution.
I have a Bushbaby Explorer with a 912 UL 80 HP engine with a 2.27 gearbox. I cannot find out if my gearbox can be changed to 2.43 ( I was told this would make a major difference) as it is very old, I think 1994. In any case, the cost to change the gearbox is quite high. I currently have an old taper tip warp drive and want to replace the 3 blades with new square tip blades.
If there is grass between your toes , you're flying to low.....
If ever in doubt about flying - drink a beer.
That will give you at least 8 hours to think about it some more.
ZU-EPH Bushbaby Explorer 912UL (Morph built)
- Duck Rogers
Re: Which prop?
It's a no-brainer Gadget.
Ask Piet de Necker....
- Gadget
- I hate turbulence
Re: Which prop?
Thanks Duck. I just feel ashamed calling him because his props don't work on my gearbox which means I am not worthy!
Re: Which prop?
Gadget wrote:Thanks Duck. I just feel ashamed calling him because his props don't work on my gearbox which means I am not worthy!
Hoe nou
Cheers Sanna
P.s. please I really dont know what Im missing, you know Im not too bright, soos die hoof gese het, "mevrou jou seun is nou nie akademies aangele nie"
Re: Which prop?
2.27 gearbox = 1x P-prop of 72 inch diameter x 47 inch pitch. Static RPM should be 5100-5300. This should give a nice climb-cruise combination.
- Gadget
- I hate turbulence
Re: Which prop?
Hi.
Aerosan. I haven't spoken to prop piet yet but everyone is telling me he is not fond of the 2.27 due to a harmonics issue. That is now if I understand the singing story correctly. No use pissing of the oracle by not having my facts straight. So I thought to first come here and ask he's trusty followers for advice. I have heard only good things about he's props and would love to have one. However, I already have the warp hub etc., but I am keeping my options open.
Jeantree. Thanks for the info. That static sound a bit low. my engine is rated at 5800 for three minutes and then 5500 all day long. Does that compute? Maybe explain a bit as I am not knowledgeable about that thing which keeps me cool.
Re: Which prop?
Gadget wrote:Hi.
Mmmmm I see
I have a very similar ratio, 2.2:1 and have no harmonics issues. If I were you Ill just get a loan prop and try it out.
Sanna
- Gadget
- I hate turbulence
Re: Which prop?
Ok. I mailed Peter and asked him to comment as well. Weird that this discussion hasn't come up on microlighters before. I did some searches but couldn't find one. I would have thought there must have been a couple of guys before me having the same issue.
Re: Which prop?
Jean.
- Gadget
- I hate turbulence
Re: Which prop?
yes. with this engine i set the static to 5600 which gives me 5800 on the climb.
- KFA
Re: Which prop?
I would go for 5200-5300 on static like Jean said. That will give you a cruise of around 95-100 in your plane and a top speed of about 115mph. The take off and climb will still be respectable at 600-800 ft/min.
I would still spend the bucks and change the gears as well as get a p prop.
I have a Explorer here in the hanger that had that exct same problem and the performance was crap compared to the new setup.
Re: Which prop?
What price are you talking about?
- KFA
Re: Which prop?
Not sure abou the gears but a prop should be about 8500. I think the gears are About 5500
- KFA
Re: Which prop?
Remember there are 2 types of gear sets. Open the gearbox first and measure the width of the gears.
- Gadget
- I hate turbulence
Re: Which prop?
I am waiting for Pieter to get back on to me on my last email. But thus far it seems the best would be to save little longer and go for the p-prop and the gears. I will take your advise and start with a static at
5200 and see what it does. The one problem I still have is that my engine is very old, apparently some of the older models cannot be upgraded and I need to check with Rotax first. I will email them today and find out. KFA, does that bushbaby also have a 912 UL 80hp?
