Change pop
topflight
Survived first engine out
Change pop
Postby topflight » Tue May 22, 2012 9:33 am
Ok, I had a look at a few trikes (I want to buy one) but there are few stuff I would like to change on them. I don’t like the wooden prop on a trike, how much will it be to change from a wooden to NC or Warp drive prop?
The reason I don’t like the wooden prop is just because I don’t know it. I have never flown in a trike with one and it seems to me that it cost more to maintain.
topflight
Re: Change pop
Postby topflight » Tue May 22, 2012 9:46 am
I probably will have to add that it will be on a 582.
Aerosan
Re: Change pop
Postby Aerosan » Tue May 22, 2012 1:54 pm
Topflight, get a WARP, IVO or whatever you like and try it out. Then put the wooden prop back on and fly with peace of mind (-) Just by changing my prop to a P-prop I have doubled my climb rate and come down on fuel consumption.
If it’s a P-prop think twice
Just my 2C
topflight
Re: Change pop
Postby topflight » Tue May 22, 2012 2:01 pm
Aerosan wrote:Topflight, get a WARP, IVO or whatever you like and try it out. Then put the wooden prop back on and fly with peace of mind (-) Just by changing my prop to a P-prop I have doubled my climb rate and come down on fuel consumption.
Just my 2C
How do one maintain the wooden prop? Does it not take up water and expand?
bobthebuilder
Re: Change pop
Postby bobthebuilder » Tue May 22, 2012 5:17 pm
Nothing wrong with wood.
Just turn the prop to a horizontal position when you finished flying.
........ I should probably add that I have never owned a wooden prop apart from a few RC ones. ^
Byron Kirkland
Re: Change pop
Postby Duck Rogers » Tue May 22, 2012 8:09 pm
topflight wrote:How do one maintain the wooden prop? Does it not take up water and expand?
Nope.....just drill a few little holes in it and the water runs straight out
wiskeyfoxtrot
Re: Change pop
Postby wiskeyfoxtrot » Thu May 24, 2012 7:27 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Only the Duck !
Aeroprakt A22 Foxbat
ZU - DYE
Sport Cruiser
ZU - LSA
Graham Mac
Re: Change pop
Postby Graham Mac » Thu May 24, 2012 9:21 pm
They dont call me the "PROP MAN" for nothing other than.....Ive been through 3 in the last 6 months
WOODY P PROP...great reliable robust prop..only down fall is vibration vs three bladers.
Thrust execellent.R????? ASK Pieter de nekker Probably around R8500 +
Warp Drive...good prop but old versions prone to hub crack development.Warp Drive takes responsibility and resolves the problem.R10000 LANDED From usa (HEARD R13000)
NC Prop...can take a hammering and still fly you to safety.no vibration.Not as hardy to stone chipping..locally made and new blades can be made available.R8500.00 NOW
I now fly with an NC PROP..Great Prop.
Any Prop worth buying is not cheap..dont knock the "woody" it will probably be the longest lasting out of all....still will keep my "HALF A TREE" forever..its there when i need her.
of a soaring bird
bobthebuilder
Re: Change pop
Postby bobthebuilder » Thu May 24, 2012 10:53 pm
Three props in the last six months .... Did you drill holes in it like the duck said? (**)
Byron Kirkland
Graham Mac
Re: Change pop
Postby Graham Mac » Fri May 25, 2012 6:50 am
a long complicated story....and a very expensive learning curve
could have been worse
of a soaring bird
Re: Change pop
Postby nicow » Fri May 25, 2012 8:02 am
Graham Mac wrote:a long complicated story....and a very expensive learning curve
Write your story and sent it to Allen for the magazine-we want to read about it.
topflight
Re: Change pop
Postby topflight » Fri May 25, 2012 10:28 am
Don't you want to share for all of us to learn?
Thank you for the info...I must drill holes in a wooden prop to make flute like sounds, it vibrates without the added cell phone electronics to enable it to do so and it last longer than any other prop :shock: :-? :-(-(
Now it only depends on what trike I will buy, but I think the best option will be to go for an NC prop.
JvTonder
Re: Change pop
Postby JvTonder » Sat May 26, 2012 9:23 am
Remember if you look after your wood prop it does not have a service life, can still go on long after you departed this earth! Had a warp and replaced with a P prop and best decision I ever made, better climb, better cruise and better fuel consumption. In short a P prop (2 blade) is a lot more efficient than a warp/3 blade.
Flying feeds the soul!
Re: Change pop
Postby Jean Crous » Sat May 26, 2012 7:01 pm
vhpy I also have a P-Prop, Oom Piet se plank works the best.......ever!!!
