Lathe work - where / whom
janjacobs66
Postby janjacobs66 » Fri Apr 27, 2012 10:46 am
Any good references ?
I need my Alu rims bearing holes "filled" & re machined
(so the bearing sits in the centre this time :lol: )
seriously !
Have 42mm OD bearings in, next size is 47mm,
that leaves me with only +/- 2mm "meat" either side, the 42mm gave me 4.5mm meat either side
- I dont know if that would be acceptable ?
Therefore the idea to close them up & size for the 42mm bearing
cant afford to ruin them, so Im asking for advice, who to use or NOT to use
Cheers !
Jan
Re: Lathe work - where / whom
Postby Duck Rogers » Fri Apr 27, 2012 3:08 pm
Where are you based Jan?
Mogas
Postby Mogas » Fri Apr 27, 2012 7:58 pm
Depending on where you are, I can sort it for you.
Ally filler weld and remachine.
Nelspruit.
oh82 41ooo32
Rick
Nottaquitta
janjacobs66
Postby janjacobs66 » Sat Apr 28, 2012 12:41 pm
Im in Kempton Park & fly from FAWI
( FAWI - don't ask - long story :lol: )
Cheers !
Jan
bobthebuilder
Postby bobthebuilder » Sat May 05, 2012 7:23 pm
What does a new rim cost?
Byron Kirkland
janjacobs66
Postby janjacobs66 » Sun May 06, 2012 1:01 pm
Locally I cant find anybody selling them, the one's willing to bring it in mention R1100 excl VAT each
I found the manufacturer selling them at $40 each (R640 a set) and they quoted $61 (R480) for shipping (no idea about import duties/VAT etc)
... problem then still, its 3" wide, then to machine them down to 2.45" width - I would guess another R1000
Next step is to get a firm quote for (1) welding up or insert a sleeve + (2) machining the bearing recess
and weigh that up against new rims ( then what are the chances that the bearing recess will be centre on the new one's ?? )
Cheers !
Jan
bobthebuilder
Postby bobthebuilder » Sun May 06, 2012 1:56 pm
What aircraft is attached to the wheel?
Byron Kirkland
bobthebuilder
Postby bobthebuilder » Sun May 06, 2012 2:00 pm
The welding may have to be done my a coded welder, and the entire mod will have to be signed off by an AP.
Personally, I would feel more comfortable with a new rim.
Byron Kirkland
janjacobs66
Postby janjacobs66 » Sun May 06, 2012 2:02 pm
Streak Shadow
The rims are from a Go-Kart, Tri-Start series made by Azusa
Cheers !
Jan
janjacobs66
Postby janjacobs66 » Sun May 06, 2012 2:05 pm
bobthebuilder wrote:The welding may have to be done my a coded welder, and the entire mod will have to be signed off by an AP.
Point is, only problem with the rims are that some idiot machined the bearing recess off centre,
otherwise they are perfect - so all I have to do is get that part sorted with welding / sleeve - an AP would be very happy to sign that out :wink:
My reason for NOT just buying a new set is simple, Im already R25K over budget :oops:
Cheers !
Jan
janjacobs66
Postby janjacobs66 » Mon Jun 04, 2012 3:50 pm
Some feedback on my wheel issue,
I found a company ( by word of mouth reference ) called Turning Tony in Foundersview - Edenvale
011 452 3 niner 7 niner
As u guessed, Tony is the man & he sorted everything out, ( one of the last few true artisans left )
re-sleeved the rim (bearing recess), turned the axle to the right dimensions,
trimmed the two halves to fit perfectly and lastly after mounting the drums,
machined them to run true
Now I have 20x less roll resistance, & brakes that actually decreases speed controllably v.s. a solid lock
p.s. The whole job was R1200, excl bearing @ R55 odd each
Cheers !
Jan
