Aquilla 1 Frame Rebuild ZU-???
Reuben zu-ccm
Postby Reuben zu-ccm » Mon Apr 23, 2012 7:44 pm
Hi All
Just some pic s on Aquilla frame Rebuild also need spares for Aquilla 1 will add as i go along if you have some laying around give a shout new or used
Need Rubber Boots
Front Rubber boot.jpg (31.82 KiB) Viewed 3816 times
Need new Rear axels left and RIght
TEST Aquilla Frame.jpg (33.81 KiB) Viewed 3816 times
Back shock Spats
Pics frames 1.jpg (29.25 KiB) Viewed 3811 times
New Wheels
Pics frames 2.jpg (29.44 KiB) Viewed 3811 times
Re: Aquilla 1 Frame Rebuild ZU-???
Postby Air Hog » Thu Apr 26, 2012 6:54 am
Hi Reuben
Julle moet vinger trek, ons mis julle by Kroon! ##
Reuben zu-ccm
Postby Reuben zu-ccm » Wed May 02, 2012 8:17 pm
Hi johan
Ek sal seker terug wees by die middle van june is besig met Aquilla en Cosmos met jenya vlerk het weer toets gevlieg en is weer reg om te vlieg hoe lyk die hanger spasie? .?
groete
Reuben
Bulletjie
Postby Bulletjie » Wed May 02, 2012 8:44 pm
Reuben, vir jou maak ons plek!
Loco
Postby Loco » Fri Jan 18, 2013 6:44 am
Hi Reuben is dit hierdie trike wat laas week daar by Rhino was?
Anthony Hugo
Crosswinds
Reuben zu-ccm
Re: Aquilla 1 Frame Rebuild ZU-BGE
Postby Reuben zu-ccm » Mon Jan 28, 2013 7:16 pm
Hi Antony
Yes fitted my wing today and hope to do high speed runway testing for a hour asp and then to the skies for me
Garfield
bobthebuilder
Postby bobthebuilder » Sun Feb 03, 2013 11:37 pm
Hi Reuben,
Your trike is looking great. Very neat and tidy.
Just an observation ......
What grade of bolts did you use on the undercart? I'm not sure that common hardware variety grade 8.8 bolts are suitable. They may be, but rather ask your AP to check them.
The purists will tell you that the bolts are also too long.
Best regards,
Byron
Byron Kirkland
Postby Boet » Mon Feb 04, 2013 7:17 am
8.8 grade bolt are more than strong enough. Just make sure that the thread is not "inside" whatever you are bolting together. The grip length, ie, the shank of the bolt measured from underneath the head of the bolt, to where the thread starts, MUST portrude slightly out of what you are bolting together, so add a washer or two. OK, the threaded part is always hopelessly to long, and looks crappy, but if you cut it shorter, PAINT tha damn thing, otherwise it will rust. Your workmanship looks very neat!! (^^)
Reuben zu-ccm
Postby Reuben zu-ccm » Sun Mar 10, 2013 7:37 pm
Thanks you guys
Rebuild commpleted and flying ZU-BGE
Reuben
