Mounting a Radiator on 582 Silver Top
WhiteEagle
Postby WhiteEagle » Tue Mar 20, 2012 8:34 pm
Anyone maybe have scematic's, pictures and/or measurements to have a radiator build and fitted on the 582 Silver Top? Help would be much appreciated.
"Good judgement usually comes from experience. Experience usually comes from bad judgement."
John.com
Re: Mounting a Radiator on 582 Silver Top
Postby John.com » Tue Mar 20, 2012 9:38 pm
YES PLEASE!! I cannot wait to see this!
I tried to get mine OUT the other day for a repair and simply gave up! The four rubber mounting brackets are IMPOSSIBLE to remove!! I ended up using Pratley's Steel instead for an in situ repair!! :shock:
Let's see what gets posted!
Cheers,
John
John Comley
Magaliesberg, South Africa
KFA
Postby KFA » Wed Mar 21, 2012 1:06 pm
What type of plane?
WhiteEagle
Postby WhiteEagle » Wed Mar 21, 2012 3:12 pm
Aquilla, was Aquilla 503.
bobthebuilder
Postby bobthebuilder » Thu Mar 22, 2012 7:05 pm
Don't muck about!
Order the radiator frame from the factory.
Will it fit on the 503 engine mount? If not order that too. Not going to be cheap, but it will be done right.
Byron Kirkland
