Tuning Rotax 503
Alpha
Tuning Rotax 503
Postby Alpha » Sat Mar 10, 2012 5:59 pm
Hi All,
I am hoping someone here can help...Ducky..I am hoping for some words of wisdom here...
I have a rotax 503 (duh??) All setup correctly , well according to me that is. However I have one problem...I cannot achieve the correct Max RPM when on the ground...Max I get 5950rpm...
I have recently changed my prop...but i cannot believe that would be the reason...I used to have a 63X34 P Prop and now I have a 63 X 35...I don't think the 1 inch change in pitch will make such a huge difference. There is a guy in my hangar that swing swings a 72 X 35, so I don't think it is the prop length either...
The answer to the problem could lie somewhere in the fact that my fuel consumption at cruise (5500) is about 19-20l/hr...
Carbs balanced and synchronised...idle perfect at 2080rpm...Pllllleeeeeeeaaaaassseee Help!!!...
ZS-WGT
ZU-AAS
German
Re: Tuning Rotax 503
Postby German » Sat Mar 10, 2012 9:43 pm
Jets?
HENNING JOHAN
Postby HENNING JOHAN » Sun Mar 11, 2012 7:54 am
Alpha wrote:Hi All,
Hallo,Gary!I had a 63x34 geo kelly prop on cai with a b-box.Max rpm in the air was 5850.I got now a ivo prop and it gets 6300rpm.Carbs was rebuild 1year and 3 months ago.My trike also idle around the rpms that you have.I think it is the prop.Regards Johan. (^^) That 72x35 is maybe a c box?
nickjaxe
Postby nickjaxe » Sun Mar 11, 2012 11:21 am
A 1 inch difference in pitch will make a huge difference...and the engine needs to make its stated RPM,
To course a pitch with a 2 stroke and it will run rich...to fine and it will run weak with associated high EGT,
What tach where you using...a/c tach can be quite a few hundred RPMs out....and what type of a/c is it.
Nick.
Postby Duck Rogers » Sun Mar 11, 2012 6:41 pm
I might be going your way this coming weekend.
You want me to come and fix it?
It will cost you a hamburger and a coke :lol: :lol:
and if I can't fix it, I'll "return" the hamburger.. ^?^
Alpha
Postby Alpha » Sun Mar 11, 2012 9:33 pm
Hahaha @ duck,
If you are in the area that would really be appreciated... As for the hamburger... No returns haha!!!
Duck, your help would really be appreciated. Thanks (^^)
ZS-WGT
ZU-AAS
