NC Prop
Bulletjie
NC Prop
Postby Bulletjie » Thu Feb 23, 2012 11:42 pm
Could anybody please help me? What is the correct pitch setting (degrees) of a NC prop on an Aquailla and what is the torque settings on the bolts to tighten the blades again? :roll:
ZS-NEL
Re: NC Prop
Postby ZS-NEL » Fri Feb 24, 2012 12:05 pm
Call Nigel Coutts the man himself from NC props on zero11 788 3297 or 082 457 zero722
Vir die boute vasdraai is maklik. Jy draai tot net voor hy strip en dan 'n kwart draai terug. :twisted:
Bulletjie
Re: NC Prop
Postby Bulletjie » Fri Feb 24, 2012 2:07 pm
Thanks Marius! I spoke to Nigel and he gave me all the dope I needed. vhpy
Hy verskil net met die boute se vasdraai. As jy hom gedraai het tot net voor hy strip, moet jy hom 'n halwe draai terugdraai :twisted: (**) (^^)
Bulletjie
Re: NC Prop
Postby Bulletjie » Fri Feb 24, 2012 2:11 pm
For those that need the info: Its 24 degrees and the bolts must be toqued to between 10 and 12 nm
