Microlight Rating Codes
KlapperKnop
Postby KlapperKnop » Fri Jan 13, 2012 7:13 pm
Does anyone know what the Z rating code is for a Cosmos Trike? Does it fall under Winlass?
ZU-DJE
Kalahari
Survived first engine out
Re: Microlight Rating Codes
Postby Kalahari » Fri Jan 13, 2012 7:56 pm
Cosmos Trike AFAIK is: Z023
Arrogance and rudeness are the training wheels on the bicycle of life for those who can not keep their balance without it!
KlapperKnop
Postby KlapperKnop » Fri Jan 13, 2012 8:18 pm
Thanks Kalahari
ZU-DJE
Kalahari
Postby Kalahari » Fri Jan 13, 2012 8:34 pm
Pleasure, you can check somewhere on Avcom is a topic: Aircraft Designation, there was a link to the different aircraft codes.
Hoke
Postby Hoke » Sun Jan 15, 2012 4:44 pm
It seems the avcom topic (http://www.avcom.co.za/phpBB3/viewtopic ... 8&start=15) references a topic on this forum (viewtopic.php?f=1&t=14976&p=148311&p148311)
They also point to an ICAO search engine, but it's giving server errors at the moment: http://www.icao.int/publications/DOC864 ... earch.aspx
aeroden
Postby aeroden » Mon Jan 16, 2012 6:35 am
The Cosmos is Z019 xxx
Postby Duck Rogers » Mon Jan 16, 2012 7:17 am
Here's the list.. vhpy
It's not up to date though but its better than nothing
ZCodes.doc
(33.5 KiB) Downloaded 387 times
Kalahari
Postby Kalahari » Mon Jan 16, 2012 10:09 am
What will the Z code for a Cheetah be, did not see it on the list?
Hoke
Postby Hoke » Mon Jan 16, 2012 10:16 am
Kalahari wrote:What will the Z code for a Cheetah be, did not see it on the list?
CTAH
Postby Duck Rogers » Mon Jan 16, 2012 10:40 am
CTAH
Huh???
flybynite
Postby flybynite » Mon Jan 16, 2012 1:13 pm
Cheetah NPL code Z194
Cheetah PPL code X254
Kalahari
Postby Kalahari » Mon Jan 16, 2012 3:29 pm
Thanks Larry.
( I thought there is a reason why Hoke and Hoax sound almost similar)
Hoke
Postby Hoke » Mon Jan 16, 2012 3:33 pm
ICAO lists it as CTAH? See my link above (operational now)
