Genius! Watch the video clip.... makes so much sense.
http://www.popularmechanics.co.za/artic ... 2010-09-22
Up to 50% more effiecient than a 4 stroke engine...
Death of the two stroke? Think again!
- Duck Rogers
Re: Death of the two stroke? Think again!
Get the ignition timing wrong on this one and watch it destroy itself..........
- Leprachaun
Just spent the day with Witwillem , he is busy with His "blue block red top 503" that kicks ass with a 582 , interresting combination.
The original 503 is used with Mazda 323 pistons , Electronic ignition , nice porting and a solid machined Testarossa steel cylinder head which is watercooled ,battles to start , but whenit eventually fired up due to a faulty fuelpump all hell breaks .he has an belt driven "Cam"which acts as a waterpump and variable porting as a 70 Hp Rotax .
I just have me doubts if the crank and pistons will take the strain - even fitted with water/ steam injection.
Needs some cosmetic paint work and within two weeks if it does not self destruct the will test fly it at Rust der Winter dam on a flat bottem swamp boat fitted with a rotax cBox and a 72inch 582 prop - 3: 1 ratio - presently trying to super tune the megaphone exhaust - Sliced the Rotax zoom tube to bits - interresting project - wandered why they were
quiet for some time Leprachaun
- bobthebuilder
Is it worth playing with mods like this?
You put your life on the line for what?
Byron Kirkland
Hi Bobbobthebuilder wrote:Is it worth playing with mods like this?
Plenty a time this is the building blocks for something better. This is the way technology finds it's way into the open
I say go for it guys
- bobthebuilder
I would rather leave it to the folks like Rotax who have big budgets and plenty of development rescources.
My 2c
My 2c
Byron Kirkland
Yes that is a definate but it is still interesting to watch the Development.bobthebuilder wrote:I would rather leave it to the folks like Rotax who have big budgets and plenty of development rescources.
My 2c
Similar to the Guys using the Yaris (Spelling Sucks i know) Motor for their trike.
- Duck Rogers
What's the problem then?bobthebuilder wrote:Is it worth playing with mods like this?
I don't see him saying he's gonna fly with it. I read they putting it in a "flat bottom swamp boat" on the water...
- bobthebuilder
Ahh yes Duck.... Alex also used the words "will test fly it at Rust"
Symantics ....
If an AP signed out this experimental engine for use on an aircraft, and an engine related accident occured, will the AP be in hot water in terms of liability?
How is the element of experimentation intoduced in the current rigid maintenence procedure?
There must be some allowance, or is there?
Symantics ....
Byron Kirkland
